Welcome to Cisco Firewalls Community
228
Engager
Lock down SIP ports with External SIP Provider
hi,
i need to lock down SIP ports on an ASA FW towards our internal SIP/voice GW:
external SIP 208.x.x   <>  ASA FW  <> 66.x.x.x internal voice GW
per my google, SIP is TCP/UDP port 5060 but i can see some had 5061.
there's also the dynamic/ephemeral port range 30,000 - 50,000+ and RTP range 16,000 - 32,000+
but on my FW show conn, i can see UDP port 5060 only and few low dynamic ports, i.e. 18890, 19718, 20250:
i would like to know what ports/range i needed to allow?
asa# sh conn
160 in use, 4408 most used
UDP outside 208.x.x.10:0 inside 66.x.x.7:5060, idle 0:09:21, bytes 0, flags ti
UDP outside 208.x.x.12:36076 inside 66.x.x.7:27938, idle 0:00:00, bytes 1634684, flags m
UDP outside 208.x.x.12:0 inside 66.x.x.6:18891, idle 0:01:32, bytes 0, flags mi
UDP outside 208.x.x.12:0 inside 66.x.x.6:18890, idle 0:01:48, bytes 0, flags mi
UDP outside 208.x.x.x:0 inside 66.x.x.6:5060, idle 0:03:58, bytes 0, flags ti
UDP outside 208.x.x.x:36544 inside 66.x.x.6:19718, idle 0:00:00, bytes 795520, flags -
UDP outside 208.x.x.x:0 inside 66.51.33.6:5060, idle 0:20:06, bytes 0, flags ti
UDP outside 208.x.x.x:34708 inside 66.51.33.6:20250, idle 0:00:00, bytes 3876560, flags m
i plan to configure ACL as below. appreciate if someone can confirm. TIA!
object-group network SIP-EXT
description ### EXTERNAL SIP GW ###
network-object host 208.x.x.10
network-object host 208.x.x.12
object-group network SIP-INT
description ### INTERNAL VOICE GW ###
network-object host 66.x.x.6
network-object host 66.x.x.7
object-group service SIP-PROTOCOLS
service-object udp destination eq 5060
service-object tcp destination eq 5060
service-object udp destination range 32768 61000
access-list SIP-OUTSIDE_ACL extended permit object-group SIP-PROTOCOLS object-group SIP-EXT object-group SIP-INT
1 REPLY 1
Advocate
Re: Lock down SIP ports with External SIP Provider
Content for Community-Ad
August's Community Spotlight Awards
