09-25-2017 05:04 PM - edited 02-21-2020 06:21 AM
Hi I am trying to dtermine whetehr of not the 5515-x will support an ethernet module as we need to add port capacity. This is the module i would like to add. ASA-IC-6GE-CU-B=
Some documents tend indicate its not possible - but I have seeen instances where these modules (or similar) have been deployed).
Solved! Go to Solution.
09-25-2017 07:17 PM
According to Cisco doc, 5515 supports ASA-IC-6GE-CU-A= , which looks like to be the very same thing.
6-port Copper or 6-port SFP: ASA-IC-6GE-CU-A= & ASA-IC-6GE-SFP-A= (ASA 5512-X,5515-X),ASA-IC-6GE-CU-B= & ASA-IC-6GE-SFP-B= (ASA 5525-X),ASA-IC-6GE-CU-C= & ASA-IC-6GE-SFP-C= (ASA 5545-X,5555-X)
09-25-2017 07:17 PM
09-26-2017 12:57 PM
