Multi Context - limiting connection resources
johng231
Level 3
Level 3
Hello-
I have setup a class-map to limit the number of connections for each separate contexts. I'm seeing an issue after applying it where the threshold is exceeding: "Drop-reason: (rm-conn-limit) RM connection limit reached"; however, the show resource usage shows the current and peak is no way near reaching the limit, only showing a couple of connections.
Version 9.1(4)
class default
  limit-resource All 0
  limit-resource Mac-addresses 65535
  limit-resource ASDM 5
  limit-resource SSH 5
  limit-resource Telnet 5
  limit-resource Conns 0
class FW-GEN
  limit-resource Conns 300000
class FW-EC
class FW-MAIN
class FW-MARK
class FW-PCI
class FW-BUBBLE
  limit-resource Conns 100000
class FW-LAB
  limit-resource VPN Other 10
Resource                 Current        Peak      Limit        Denied Context
SSH                            1           2          5             0 admin
ASDM                           0           4          5             0 admin
Conns                          3           7  unlimited             0 admin
Hosts                          3           7  unlimited             0 admin
Inspects [rate]                0           7  unlimited             0 admin
Routes                         2           2  unlimited             0 admin
Conns                          0          40      99000             0 BUBBLE
Hosts                          0          32  unlimited             0 BUBBLE
Conns [rate]                   0         125  unlimited             0 BUBBLE
Inspects [rate]                0          25  unlimited             0 BUBBLE
Mac-addresses                  0           2      65535             0 BUBBLE
SSH                            0           2          5             0 LAB
Syslogs [rate]                 0         147  unlimited             0 LAB
Conns                          2         178     299000         22830 LAB
Xlates                         3         423  unlimited             0 LAB
Hosts                          3          72  unlimited             0 LAB
Conns [rate]                   0         250  unlimited             0 LAB
Inspects [rate]                0          67  unlimited             0 LAB
Routes                         9          10  unlimited             0 LAB
Other VPN Sessions            43          45         10             2 LAB
Other VPN Burst                0           1          0             0 LAB
Packet-Tracert input inside
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Is there anything else I can check to see why the connection limit is being reached?
6 Replies 6
Maykol Rojas
Has to be a new/Existing bug.
Please send me a message, if you need to solve this right away, go ahead and open a ticket.
Mike
Mike
I am having the exact same problem with ASA 5555 9.4, any updates on this?
- Make sure you have upgraded to the latest version of ASA, SFR and FMC versions
- Make sure you do not have have not set unlimited connection timeouts on the Inside-Interface
- Make sure you have left Inside-Interface Per-client-max = 0 (default) , Per-client-embryonic-max = 0 (default) and Idle= 0 (default)
That Solved the Problem For me!
Jigar Dave
Level 3
Level 3
limit on conn resources depend upon which hardware model you are using
this (http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/license.html#wpxref10155 ) shows table per hardware.
I am also interested to know if this is bug in the OS.
JD...
I have opened up a ticket. I'll keep everyone posted on the findings.
The ASA hardware is a pair of 5585x SSP40 and it's not in production. We are only testing this in the LAB using multi context with a policy to restrict the number of connections so in case where one context gets overwhelmed, it won't affect the others. Looking for a simple class policy to apply to each context.
John
Looks like a new one. I found the ticket. Will keep an eye on it.
Mike
Mike
