Welcome to Cisco Firewalls Community
65
NAT and ACL clarification.
Hello, I have a small  quick question on ASA
Object-group test
 host 10.10.10.10
 nat (inside,outside) static 1.1.1.1 service tcp 1683 1683
and if I have a ACL entry from outside in into inside as below, will protocol 80 will work? or just only 1683
permit ip any host 10.10.10.10 service eq 1683
permit ip any host 10.10.10.10 service eq 80
Thanks in advance,
1 REPLY 1
Hall of Fame Guru
It will only allow the port
It will only allow the port you have specified in the NAT statement so no it won't work assuming you have no other NAT statements for that host.
If you want to allow other ports you need further NAT statements.
Jon
