Welcome to Cisco Firewalls Community
508
Beginner
nat from inside to dmz using 8.4
                   I need to configure nat from inside to dmz, i have already configured one network object and now need to apply static nat from inside tor dmz
It seems that you have to apply when the network object is being created but I am confused to how you amended Nat to the object after creation
The nat command i believe is nat (inside,dmz) static object_name
Any help would be greatly appreciated
Everyone's tags (4)
2 REPLIES 2
Actually there are 3 different ways to configure NAT on 8.3 or higher versions. Right now you are refering to the auto-nat but at least my opinion is to go with the Twice nat at this is the first taken into consideration by the ASA
Do the following
nat (inside,dmz) source static Real-IP_Object Mapped_Ip_Object
Any other question..Sure.. Just remember to rate all of my posts
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Participant
If you still want to use auto-nat, it is as follows:
******create the object*******
object network Real-IP
host 1.1.1.1
***** enter the object subcommand mode and add the nat rule********
nat (inside,dmz) static mapped-IP
After the static keyword, you can use an IP address, network object or the interface keyword.
Note: NAT for traffic between interfaces is no longer a requirement after version 8.3
Felipe
