NAT from outside to inside
arshad_cisco86
Hi ,
kindly suggest the configuration URL for natting from outside to inside interface .
Arshad Ayub
5 Replies 5
Akira Muranaka
Level 8
Level 8
I think this document will help you. See "ASA Version 8.3 and Later" setting if you use ASA 8.3+ version.
NAT and PAT Statement Use on the Cisco Secure ASA Firewall Configuration Example
http://www.cisco.com/c/en/us/support/docs/security/pix-500-series-security-appliances/15243-19.html#anc4
Hi Akira , Thanks for this ..
But i need dynamic NAT for outside to inside ...(CCIE TOPIC)
Arshad Ayub
Hi Arshad,
You could configure Outside nat. Use the link below :
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/nat_dynamic.html#wp1079227
Outside nat is configured by using 'outside' keyword at the end ot nat statement. Use the above link and search for ' Outside NAT and Inside NAT Combined'.
Hope it helps.
Akshay Rastogi
Remember to mark the answer as correct if it answers your queries or rate the helpful posts.
Hi Akshay ,
above link is very usefull for me .....
I got some configuration retaled to this, your suggstion is also very perfect for me .
Thanks  you very much
Arshad Ayub
Hi Arshad,
You are welcome.
Akshay Rastogi
Remember to mark the answer as correct or rate the helpful posts.
