NAT Interface Outside in Cisco ASA 8.3 above
fara.rhea
Guys,
Do you have any experience with "NAT outside interface" in Cisco ASA 8.3 above ?
I have a problem
I want to do NAt-ing like this :
InsideY.Y.2.14X.X.2.66
DMZ-10X.X.2.11X.X.2.66
I have interface outside with ip address X.X.2.66, i want to do NAT in traffic from Zone inside with ip address Y.Y.2.14 to ANY, i want to change that traffic to X.X.2.66 and i want to do NAT traffic from Zone DMZ-10 ip address X.X.2.11 to ANY i want to change that traffc to X.X.2.66.
I do this configuration :
nat (DMZ-10,outside) source static X.X.2.11 interface
nat (inside,outside) source static X.X.2.11 interface
this configuration work, the traffic from Zone inside (X.X.2.11) and Zone DMZ-10 (X.X.2.14) will be NAT to X.X.2.66 with warning message like this :
WARNING: All traffic destined to the IP address of the outside interface is being redirected.
WARNING: Users may not be able to access any service enabled on the outside interface.
But now i can't access ip X.X.2.66 from outside.
Is there any correct configuration to do NAT in interface ? Because i want to access interface outside from outside network ?
BR
Fara
Jouni Forss
If you want to PAT the traffic from the 2 source hosts behind 2 different interfaces to the "outside" interface IP address then you can use the following configurations
object-group network PAT-SOURCE-ADDRESS
network-object host y.y.2.14
network-object host x.x.2.11
nat (any,outside) after-auto source dynamic PAT-SOURCE-ADDRESS interface
The above configurations is meant to
  • Allow the 2 source hosts to access Internet using the public IP address of the "outside" interface of the ASA
  • If you want to add a whole network or more hosts to be NATed to the same public IP address you can simply add those under the "object-group" we created.
The reason why you have problems with access to ASA is that you statictly bind the whole public IP address to be used by a single LAN host
EDIT: Notice that you have to remove the NAT configuration you made and mentioned in your original post.
- Jouni
