Welcome to Cisco Firewalls Community
189
Beginner
NAT question with sw 9.1
Hi, this is probably a simple NAT question but I can't find answer.
From my inside interface with security level 100, I can access servers on the dmz interface with security level 50.
But if I publish a server on the dmz interface to outside, i can no longer connect to it from inside.
I publish the server with the command:
object network server-name
host 10.50.50.10 (ex ip to server)
nat (any,any) static 216.22.34.46 (ex public ip)
I have an acl on the outside interface in and allow traffic to the server. It all works well from outside internet --> to the server on the dmz. But i do not have access from an inside host to the server.
I assume it have to do with the NAT command?
I'm using an asa 5512-x with sw 9.1
1 ACCEPTED SOLUTION
Beginner
Hi Johan,
You are using "nat(any,any)", so dont use that as you know that the server that you are publishing is on dmz and you are publishing it for traffic from outside interface
Use this instead
nat (dmz,outside) static 216.22.34.46 (ex public ip)
Try this i am sure this will make it work for both inside users as well as outside users.
Cheers,
Naveen
2 REPLIES 2
Beginner
Hi Johan,
Use this instead
Cheers,
Naveen
Beginner
Thanks Naveen, it works
Content for Community-Ad
FusionCharts will render here
