With reference to attached deployment scenario , need to understand on the following Failover use cases:
Case 1 : Link Failure - If the link to the Primary Nexus Switch Fails then will the secondary Nexus switch become active ? and how will the traffic be diverted through the Firewalls ? What will be the traffic path
Case 2 : Switch Failure - If the Primary Nexus Switch Fails and the Firewall is monitoring Po2 for failures , then will there be a failover at Firewall Level also ?
Case 3 : Firewall Failure - If the Primary Firewall Fails and the secondary become active, then what will be the traffic path considering that the Secondary Member is connected to only Switch 2 , will this be the traffic flow in this case : Secondary Firewall (Active) - HSRP Standby Swtich - Peer Link - HSRP Active Switch - AWS
