NGFWv-AWS - EBS volume encryption issue
varunes10
I am running multiple NGFWv in our AWS environment from the marketplace. When trying to setup the EC2 instance for the firewall image and if I selected to encrypt the ebs volume with default aws/ebs key then the appliance does not respond on boot up. I also do not see any system logs for the EC2 during boot up. I do see system logs while terminating the instance. We have a policy to have all ebs volumes encrypted else will be flagged non compliant. Does the NGFWv support encryption of the ebs volume in AWS? Any insight into this will be helpful. Thank you.
System logs on shutting the instance down.
IO memory blocks requested from bigphys 32bit: 87680
INIT: version 2.88 booting
Starting udev
Configuring network interfaces... done.
Populating dev cache
TODO: Remove /tmp/disable_dpdk to enable dpdk on ngfwv
Found virtual boot drive /dev/xvda1
Found virtual disk0 drive /dev/xvda2
fsck.fat 3.0.28 (2015-05-16)
Starting check/repair pass.
FATs differ but appear to be intact. Using first FAT.
Cluster 258046 out of range (207673272 > 2092549). Setting to EOF.
Cluster 258047 out of range (223535692 > 2092549). Setting to EOF.
Cluster 258048 out of range (10059955 > 2092549). Setting to EOF.
Cluster 258049 out of range (133079543 > 2092549). Setting to EOF.
Cluster 258050 out of range (65038938 > 2092549). Setting to EOF.
Cluster 258051 out of range (219439810 > 2092549). Setting to EOF.
Cluster 258052 out of range (46504770 > 2092549). Setting to EOF.
Cluster 258053 out of range (10103903 > 2092549). Setting to EOF.
Cluster 258054 out of range (250869187 > 2092549). Setting to EOF.
Cluster 258055 out of range (131507214 > 2092549). Setting to EOF.
Cluster 258056 out of range (79941071 > 2092549). Setting to EOF.
Cluster 258057 out of range (6384958 > 2092549). Setting to EOF.
Cluster 258058 out of range (259674023 > 2092549). Setting to EOF.
Cluster 258059 out of range (51362568 > 2092549). Setting to EOF.
Cluster 258060 out of range (262079956 > 2092549). Setting to EOF.
Cluster 258061 out of range (256313087 > 2092549). Setting to EOF.
Cluster 258062 out of range (34401673 > 2092549). Setting to EOF.
Cluster 258063 out of range (257800812 > 2092549). Setting to EOF.`
18 Replies 18
jimholla
We are working with AWS on this issue. They have identified that their decryption algorithms are returning random data for uninitialized storage blocks. More to come on this.
Thank you for the response @jimholla. Please let me know when AWS finds a resolution for this issue so I can retry deploying the image with ebs encryption.
@jimholla - Hi, is there any update on this issue with AWS? Has this been resolved on their end?
Sorry to say, but there has been no progress.  AWS has identified the issue and they were working on a fix. I'll check on the status to see if we can push this forward.
Hi @jimholla,
Has there been any update from AWS on this issue? Please let me know. Thank you.
Yes. We have tested a fix for this issue and it works! Now we need to republish our AMIs in AWS. Unfortunately that will take a couple of weeks.
Awesome. Thank you for the update @jimholla
I am still having the same issue even with the latest 6.6.0-90 ami published today.  Is there any update on this?
We have a fix for this issue but we need tom complete testing and then republish the AMIs. It will probably take a few more weeks before you can use encrypted storage.
How do you build a system without encrypted storage?
Hey there @jimholla, been a few weeks since your last message, but I still see 6.6.0-90 as the latest version for Cisco Firepower NGFW Virtual (NGFWv) - BYOL and Cisco Firepower NGFW Virtual (NGFWv) in the AWS Marketplace. Can you please give us an update as to when the fix might be released, approximately?
Thanks!
Howdy,
We've started the process of republishing AMIs to the marketplace that resolve the encrypted storage issue. The first one available is 6.4.0-113. More will be coming soon.
Jim
Has this problem been corrected?   It seem I am running into the same issue:
Screenshot from 2020-08-26 12-30-35.pngScreenshot from 2020-08-26 12-36-26.png
Not that I have seen.
I had to disable encryption to get it to load.
