Welcome to Cisco Firewalls Community
145
Beginner
Observed Spike in netflow monitoring tool
Hi Team,
we are using Solar winds monitoring tool and enabled NetFlow in ASA. everything is working perfectly expect bandwidth utilization is showing spikes. as per analysis there is no possibility for this spike because in the ISP side monitoring tool utilization is normal. we have a setting ip flow-cache timeout command to disable the flow cache parameters in the IOS. is there any similar command in ASA to disable flow-cache
