Outbound client ftp connections not working.
kscottwoody
Having trouble figuring this out.  Probably missing something simple.
I have some users that are trying to initiate a passive ftp connection to a server on the web.
I’ve setup an object group for general web traffic outbound sourced from inside.  Here’s a snippet.
object-group service web_general tcp-udp
port-object eq 21
port-object eq www
port-object eq 443
and ACL.
access-list inside extended permit object-group tcp-udp object-group myUsers any object-group web_general
the user tries to open a connection and nothing..
any ideas on troubleshooting?
Jouni Forss
If your users interface on the ASA is "inside" then first try "packet-tracer" to determine what configurations would apply for this connection
packet-tracer input inside tcp 12345 21
Also check that you have FTP Inspection enabled in your Policy Map
Use the command
show run policy-map
- Jouni
