08-28-2018 09:15 AM - edited 02-21-2020 08:09 AM
Hi all,
I wanted to know if it was possible to used a PBR on an ASA for IPSec VPN tunnels. I have a client that just upgrade to an MPLS circuit, but they have several location still on standard internet pipes. I have a backup circuit at the main location that I would like to PBR all there VPN too.
08-29-2018 12:00 AM
Can you add a diagram of what you are trying to achieve?
also, the MPLS circuit and 'internet pipes' as you call them, do the terminate on the same device?
I would think that routing. could decide to either go accross mpls or internet VPN.
08-29-2018 06:36 AM
Correct, the MPLS circuit and the "internet pipe" terminate on g0/0 and g0/2, respectively, on the ASA.
What I'm trying to achieve is 4 VPNs to remote site terminating on the internet circuit until we get those site on the MPLS cloud.
08-29-2018 08:33 AM
