06-12-2013 10:20 AM - edited 03-11-2019 06:56 PM
So everything I've read on Cisco's documentation here: http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/interface_start.html#wp1329030 says that I can create a port-channel on two physical interfaces that will uplink to a VSS pair. However, the command is not recognized. What am I missing? I've tried executing "channel-group #" on the physical interface and tried creating the port-channel 1st and neither commands exist. I haven't seen it listed anywhere if it is only available after a specific piece of ASA software. If it is the software would someone know what version at a minimum I need to upgrade to? Below is an output from a show version
Cisco Adaptive Security Appliance Software Version 8.0(4)
Device Manager Version 6.1(3)
Compiled on Thu 07-Aug-08 20:53 by builders
System image file is "disk0:/asa804-k8.bin"
Config file at boot was "startup-config"
########### up 43 days 23 hours
Hardware: ASA5520, 2048 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.05
Solved! Go to Solution.
06-12-2013 10:35 AM
You need software 8.4(1) atleast to be able to configure Port Channel / Etherchannel
Here is the section from the command reference which states this
http://www.cisco.com/en/US/docs/security/asa/asa84/command/reference/i3.html#wp1932200
Naturally in your case if you were to upgrade the ASA to 8.4(x) software it would mean that NAT configuration format would be totally different compared to your software version of 8.0.
- Jouni
06-12-2013 10:27 AM
Licensed features for this platform:
Maximum Physical interfaces: Unlimited
Maximum Vlans :150
Inside Hosts :Unlimited
Failver :Active/Active
VPN-DES :Enabled
VPN-3DES-AES :Enabled
Security Contexts :2
GTP/GPRS Disabled
VPN Peer :50
AnyConnect for Mobile Disabled
AnyConnect for Linksys phone Disabled
Advanced Endpoint Assessment Disabled
UC Proxy Sessoin :2
Matt
06-12-2013 10:35 AM
- Jouni
