Welcome to Cisco Firewalls Community
92
Beginner
Port forwording ASA 5520
Never done port forwarding before , not really sure how to do it. I have a cisco ASA 5520 running version 8.2 , I Do most of my set up with the ASDM.
I need to set up a port forwarding on the outside interface 70.xx.xx.66
so traffic bound for 70.xx.xx.66 ( main internet ip) hits ports 21012 ,21010, 21011
then the traffic would be forwarded to  inside addy 10.x.x.x port 8887 ,80,  443 .
any help would rock
Everyone's tags (1)
1 ACCEPTED SOLUTION
Beginner
I can tell you the CLi script
I can tell you the CLi script of the same.
you will need 2x things for each port-forwarding (one ACL entry and one STATIC NAT entry)
static (inside,outside) tcp 70.x.x.x 21012 10.x.x.x 8887 netmask 255.255.255.255 0 0
static (inside,outside) tcp 70.x.x.x 21010 10.x.x.x 80 netmask 255.255.255.255 0 0
static (inside,outside) tcp 70.x.x.x 21011 10.x.x.x 443 netmask 255.255.255.255 0 0
access-group OUTSIDE_IN in interface outside
access-list OUTSIDE_IN ext permit tcp any 70.x.x.x eq 21012
access-list OUTSIDE_IN ext permit tcp any 70.x.x.x eq 21010
access-list OUTSIDE_IN ext permit tcp any 70.x.x.x eq 21011
Let me know if any issues.
Please mark answer as correct if it works.
1 REPLY 1
Beginner
