PPOE ASA 5505 portforwarding ver 8.2
Lewis Goulden
I have moved from a crappy router to a cisco 5505 running software ver 8.2.
I have done the initial config and am happily surfing the net.
How ever im haveing trouble setting up port forwarding.
Can someone please tell me how i should set this up.
I want to connect to a access server on my lan via telnet.
access server ip = 192.168.1.252
telnet port default
All help is greatly appreciated !
Thanks in advance.
My config:
sec01(config)# show run
: Saved
ASA Version 8.2(1)
hostname sec01
enable password xxxxxxx encrypted
passwd xxxxxxx encrypted
names
interface Vlan1
shutdown
no nameif
no security-level
no ip address
interface Vlan10
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Vlan99
nameif outside
security-level 0
pppoe client vpdn group grp1
ip address pppoe
interface Ethernet0/0
description ** ppoe link **
switchport access vlan 99
interface Ethernet0/1
switchport access vlan 10
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
shutdown
interface Ethernet0/6
shutdown
interface Ethernet0/7
shutdown
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group home
timeout 5
name-server x.x.x.x
name-server x.x.x.x
name-server x.x.x.x
domain-name home.net
dns-group home
object-group network lg-imac
network-object host 192.168.1.252
pager lines 24
logging buffer-size 90000
logging history informational
mtu inside 1500
mtu outside 1492
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
router eigrp 10
no auto-summary
eigrp router-id 10.10.10.254
passive-interface outside
redistribute static
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh scopy enable
ssh 192.168.1.240 255.255.255.240 inside
ssh timeout 5
ssh version 2
console timeout 5
vpdn group grp1 request dialout pppoe
vpdn group grp1 localname 789@abc.cde
vpdn group grp1 ppp authentication chap
vpdn username 789@abc.cde password *********
dhcpd ping_timeout 10
dhcpd domain gouldenintra.net
dhcpd option 3 ip 192.168.1.254
dhcpd option 4 ip 212.159.13.50
dhcpd address 192.168.1.50-192.168.1.80 inside
dhcpd dns 192.168.1.254 212.159.13.49 interface inside
dhcpd lease 1800 interface inside
dhcpd update dns both interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
username abc@cde password ****** encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:cb76d45572169962de4a9f53e0651924
: end
Luis Silva Benavides
Hi Lewis,
Have you tried to do the portforwanding using the keyword "interface" on the Static NAT statement
static ( inside,outside) tcp interface 23 192.168.1.252 23
access-list outside_in permit tcp any interface outside eq 23
access-group outside_in in interface outside
Then you only will need to do a "show ip" on the ASA so you can see the current external IP address. Then you can open a telnet session and it should work.
Luis Silva
"If you need PDI (Planning, Design, Implement) assistance feel free to reach us"
http://www.cisco.com/web/partners/tools/pdihd.html
Luis Silva
I will try this shortly when i get home.
I have aquired version 9.1 (4) will the above commands work on that version ive been told lots of things change on newer versions of code.
(im following upgrade path 8.2 (currently) --> 8.4 --> 9.1.
Thankyou for your post.
Lewis,
The sintax on 8.3+ is different.
It will look similar to this:
object network obj-192.168.1.252
host 192.168.1.252
nat ( inside,outside) static interface service tcp 23 23
access-list outside_in permit tcp any host  192.168.1.252 eq 23
https://supportforums.cisco.com/docs/DOC-9129
Luis Silva
Luis Silva
