Welcome to Cisco Firewalls Community
371
Beginner
[PROBLEM]: Need Help! VPN S2S/L2L between 2 ASA 5506-X
Hello everyone, I have a problem to create a VPN L2L between 2 ASA 5506-X (see the pictures bellow).
I configure my 2 firewall inspired by the majority of tutorials found on the NET.
I correctly place client PCs in each LAN, but when I try to ping from Site 1 to Site 2 (or vice versa) it does not work.
You can see below my firewall configuration and the network map.
Network map:
ASA0:
ASA Version 9.6(1)
hostname FW2
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface GigabitEthernet1/1
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/2
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/6
 nameif inside
 security-level 100
 ip address 172.22.7.1 255.255.255.0
interface GigabitEthernet1/7
 nameif DMZ
 security-level 50
 ip address 172.22.8.1 255.255.255.0
interface GigabitEthernet1/8
 nameif WAN
 security-level 0
 ip address 172.30.1.20 255.255.255.0
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
ftp mode passive
object network obj_any
 subnet 0.0.0.0 0.0.0.0
object network LAN-inside
 subnet 172.22.7.0 255.255.255.0
object network LAN-remote
 subnet 172.21.7.0 255.255.255.0
access-list 1 extended permit ip 172.22.7.0 255.255.255.0 172.21.7.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu DMZ 1500
mtu WAN 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,WAN) source dynamic any interface
nat (inside,WAN) source static LAN-inside LAN-inside destination static LAN-remote LAN-remote no-proxy-arp route-lookup
router ospf 1
 network 172.22.7.0 255.255.255.0 area 2
 network 172.22.8.0 255.255.255.0 area 2
 network 172.30.1.0 255.255.255.0 area 0
 log-adj-changes
route WAN 0.0.0.0 0.0.0.0 172.30.1.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec ikev1 transform-set ipsec-vpn esp-aes esp-sha-hmac
crypto ipsec security-association pmtu-aging infinite
crypto map Vevey 10 match address 1
crypto map Vevey 10 set peer 172.30.1.10
crypto map Vevey 10 set ikev1 transform-set ipsec-vpn
crypto map Vevey interface inside
crypto ca trustpool policy
crypto ikev1 enable inside
crypto ikev1 policy 2
 authentication pre-share
 encryption aes
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
no ssh stricthostkeycheck
ssh 172.0.0.0 255.255.255.0 inside
ssh timeout 5
ssh version 2
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config inside
ntp server 172.30.1.1
dynamic-access-policy-record DfltAccessPolicy
username admin password f3UhLvUj1QsXsuK7 encrypted privilege 15
tunnel-group 172.30.1.10 type ipsec-l2l
tunnel-group 172.30.1.10 ipsec-attributes
 ikev1 pre-shared-key *****
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 2
Cryptochecksum:ec1455b1dc514a6b64959311a95494c8
: end
ASA1:
ASA Version 9.6(1)
hostname FW1
names
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 nameif inside
 security-level 100
 ip address 172.21.7.1 255.255.255.0
 nameif DMZ
 security-level 50
 ip address 172.21.8.1 255.255.255.0
 nameif WAN
 security-level 0
 ip address 172.30.1.10 255.255.255.0
 management-only
 no nameif
 no security-level
 no ip address
ftp mode passive
access-list 1 extended permit ip 172.21.7.0 255.255.255.0 172.22.7.0 255.255.255.0
pager lines 24
mtu inside 1500
mtu DMZ 1500
mtu WAN 1500
arp timeout 14400
router ospf 1
 network 172.21.7.0 255.255.255.0 area 1
 network 172.21.8.0 255.255.255.0 area 1
 log-adj-changes
http server enable
crypto map Lausanne 10 match address 1
crypto map Lausanne 10 set peer 172.30.1.20
crypto map Lausanne 10 set ikev1 transform-set ipsec-vpn
crypto map Lausanne interface inside
 encryption aes
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh timeout 5
ssh version 2
console timeout 0
tunnel-group 172.30.1.30 type ipsec-l2l
tunnel-group 172.30.1.30 ipsec-attributes
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
Cryptochecksum:47c8cbbb9a05fbeae874207339690a65
: end
1 ACCEPTED SOLUTION
VIP Advocate
Re: [PROBLEM]: VPN S2S/L2L between 2 ASA 5506-X
Then IP SLA is another way.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution If this comment will make help you!
7 REPLIES 7
VIP Advocate
Can you share the some outputs:
1. debug crypto isakmp 127
2.  sho crypto ipsec sa
3. debug crypto isakmp
4. sho route
Deepak Kumar
Deepak Kumar,
Beginner
ASA 0
FW2# debug crypto isakmp 127
FW2# sh crypto ipsec sa
There are no ipsec sas
FW2# sh route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 172.30.1.1 to network 0.0.0.0
S*       0.0.0.0 0.0.0.0 [1/0] via 172.30.1.1, WAN
C        172.22.7.0 255.255.255.0 is directly connected, inside
L        172.22.7.1 255.255.255.255 is directly connected, inside
C        172.30.1.0 255.255.255.0 is directly connected, WAN
L        172.30.1.20 255.255.255.255 is directly connected, WAN
FW2#
ASA 1
FW1# debug crypto isakmp 127
FW1# sh crypto ipsec sa
FW1# sh route
O IA     172.22.7.0 255.255.255.0 [110/20] via 172.30.1.20, 00:12:41, WAN
L        172.30.1.10 255.255.255.255 is directly connected, WAN
FW1#
Thank you very much.
VIP Advocate
You made some issues in routing side:
1. Why LAN subnet from both ASA are in routing configuration
router ospf 1
router ospf 1
 Remove the local LAN subnets from OSPF routing and DMZ if not required.
Here I can see that you have default route toward wan and OSPF. You can keep only one.
Deepak Kumar
Deepak Kumar,
Beginner
Thank you.
I can not delete them because if I do, my PC
from site 1 can not even ping the FW from site 2 (and vice versa).
What can I do to make the VPN work?
VIP Advocate
for configuration the VPN we need only WAN must be reachable not a lan site. Right now your traffic is not going through VPN tunnel and routing is pushing him out.
You must generate the traffic for VPN. otherwise, it will not come up.
Deepak Kumar
Deepak Kumar,
Beginner
Thanks.
But what can I use to generate the traffic for the VPN if ping doesn't work?
VIP Advocate
Deepak Kumar
Deepak Kumar,
Content for Community-Ad
FusionCharts will render here
