Welcome to Cisco Firewalls Community
690
Beginner
Problem setting up cisco ASA 5515 Ver 9.1(1)
I got the NAT problem setup in Ver 9.1(1).
object network outside-net
host 10.50.10.10
object network inside-net
host 192.168.1.10
nat (inside,outside) dynamic interface
object network www
host 192.168.1.10
nat (inside,outside) static outside-net service tcp 80 80
access-list acl-in permit ip any any
access-list acl-out permit ip any any
access-group acl-in in interface outside
access-group acl-out out interface inside
I can access internet from inside lan .
But the web server cant be accessed from internet.
The problem exist in ver 9.1 (1), but not in Ver 8.4.
Pls kindly help.
Paul
19 REPLIES 19
Beginner
Hi All,
Actually, I only want a simple configuration.
inside network = 192.168.1.0/24
outside network = 10.50.10.0/27
Inside all can access to the internet.
and we only have one web server inside = 192.168.1.10.
this can be done in ver8.x but not in 9.1(1).
pls help.
Re: Problem setting up cisco ASA 5515 Ver 9.1(1)
Hello Mw,
So here is the thing
Let's say the internal server will be 4.2.2.2 on the outside OK?
nat (inside,outside) after-auto dynamic any interface
object network Internal-Server
host 192.168.1.10
Object network Outside-Server
host 4.2.2.2
nat (inside,outside) source static Internal-Server Outside-Server
access-list out-in permit tcp any host 192.168.1.10 eq 80
access-group out-in in interface outside
That's it, a configuration from scratch for free Now remember to always rate the helpful posts hehe
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Beginner
Hi Julio,
Thanks for your reply. I'll try tmr and reply.
thx again
mw
Beginner
not work.
below is my config.
hostname ciscoasa
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 10.50.10.215 255.255.255.224
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 172.16.20.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
ftp mode passive
object network obj-172.16.20.21
host 172.16.20.21
object network obj-10.50.10.217
host 10.50.10.217
access-list acl-in extended permit udp any object obj-172.25.20.21
access-list acl-in extended permit tcp any host 172.25.20.21 eq www
pager lines 24
logging enable
logging console debugging
logging buffered debugging
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static obj-172.25.20.21 obj-210.3.166.217
nat (inside,outside) after-auto source dynamic any interface
route outside 0.0.0.0 0.0.0.0 10.50.10.193 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet 192.168.1.0 255.255.255.0 management
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
<--- More --->
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 1
Cryptochecksum:d829d2da705abcd074c24febefa1b369
: end
pls help.
mw
Hall of Fame Master
Wrong forum, post in "Security - Firewalling". You can move your posting using the Actions panel on the right.
Beginner
Hi Paolo,
Thanks.
But where is the action panel?
mw
Beginner
Hi mw,
nat (inside,outside) source static obj-172.25.20.21 obj-210.3.166.217 is wrong, no "obj-210.3.166.217" is seen from your posted configuration.
follow what jcarvaja mentioned to configure the static nat rule, it should work.
Beginner
Thx for your reply Xie,
The obj-210.3.166.217 should be replaced by  object network obj-10.50.10.217.
so, that rules also has an correct object.
but still does not work...........
the same config is work in ver 8.x.
thx
mw.
mw lam
Hello you etiher need to have both way NAT or manually change it to (outside,inside)
Beginner
thx for your reply.
However, I can go out to internet from inside by apply the following config:
ciscoasa(config)# sh run object
host 172.16.20.21
object network obj-10.50.10.216
host 10.50.10.216
ciscoasa(config)# sh run nat
nat (outside,inside) source static obj-10.50.10.216 obj-172.16.20.21
ciscoasa(config)# sh run access-list
access-list outside_access_in extended permit icmp any object obj-10.50.10.216
access-list outside_access_in extended permit tcp any host 172.16.20.21 eq www
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit icmp any any
ciscoasa(config)# sh run access-group
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
But still cant access to the web server of the object obj-172.26.20.21.
I read the post before in the forum , I also issue the command "sysopt noproxyarp outside" but also in vain.
Pls help.
mw.
One more thing. I do packet tracer, there is no problem from inside to outside. But fail from outside to inside in the step nat rules........
Config looks fine.let me ask you are u trying to access website from ur inside network using a web browser ?
Beginner
thx for your reply.
yes, I can access through browser and I can ping the domain , too. eg. ping www.yahoo.com......
Beginner
Hi Lam,
Found this in your configuration
"no arp permit-nonconnected"
Try removing this by
"arp permit-nonconnected"
Let me know if it worked...
Cheers,
Naveen
Beginner
alright, will try and let you know asap.
Content for Community-Ad
FusionCharts will render here
