Welcome to Cisco Firewalls Community
664
Problem setting up cisco ASA 5515 Ver 9.1(1)
U are not using the NAT command I provided......
If you use a ip address that is not on the same subnet than the ASA you need the command that Naveen provided it.
If you use the NAT statement that I provided there is no need for that command.
Again, Try the exact same configuration that I use Nat from inside to outside, and post the entire configuration.
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at jcarvaja@laguiadelnetworking.com
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Beginner
the config has been attached. pls comment.
ASA Version 9.1(1)
hostname ciscoasa
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 10.50.10.215 255.255.255.224
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 172.25.20.1 255.255.255.0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
ftp mode passive
object network internal-server
host 172.25.20.20
object network outside-server
host 10.50.10.216
access-list out-in extended permit tcp any host 172.25.20.20 eq www
access-list out-in extended permit icmp any host 172.25.20.20
pager lines 24
logging asdm informational
mtu management 1500
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
arp permit-nonconnected
nat (inside,outside) source static internal-server outside-server
nat (inside,outside) after-auto source dynamic any interface
access-group out-in in interface outside
route outside 0.0.0.0 0.0.0.0 10.50.10.193 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca trustpool policy
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
Cryptochecksum:2986fa151b9a81facc9113e56e262fc0
mw
ok just keep in your mind if you are trying to access your websites public ip using your internet access its not going to work. because public ip for your website is not assigned to the device and its from same pool as your outside interface. did you tried accesing your site from completlty different network ?
Beginner
Hi Arsen,
Now I only setup as simple as it is.
adsl <-- cisco asa <--  2 pc.
I can ping and browse the web between the 2 pc.
the outside subnet is 10.50.10.192/27.
thx
mw.
Beginner
Dear all,
the firewall finally has been done though its just now one-one mapping.
The problem may be caused by the uplink........
need to clarify with the provider on tmr.
sorry !!
mw.
Content for Community-Ad
FusionCharts will render here
