Problem to communicate through ASA 5506-X 9.8(1)
The topology is in the attached file.
My problem is I can't ping client 2 from client 1 and Client 1 from client 2.
Interface 2 and 3 have same security level.
Here is the configuration of the ASA :
ASA Version 9.8(1)
hostname PTF-FW002
domain-name XXXXXX
enable password XXXXXXXXX encrypted
xlate per-session deny tcp any4 any4
xlate per-session deny tcp any4 any6
xlate per-session deny tcp any6 any4
xlate per-session deny tcp any6 any6
xlate per-session deny udp any4 any4 eq domain
xlate per-session deny udp any4 any6 eq domain
xlate per-session deny udp any6 any4 eq domain
xlate per-session deny udp any6 any6 eq domain
interface GigabitEthernet1/1
 nameif Outside
 security-level 1
 pppoe client vpdn group Orange
 ip address pppoe
interface GigabitEthernet1/2
 nameif Corporate
 security-level 95
 ip address 10.38.143.245 255.255.255.248
interface GigabitEthernet1/3
 nameif AGNET-SGI
 security-level 95
 ip address 10.103.1.253 255.255.255.0
interface GigabitEthernet1/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/6
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/7
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/8
 shutdown
 no nameif
 no security-level
 no ip address
interface Management1/1
 management-only
 nameif management
 security-level 100
 ip address 10.0.0.253 255.255.255.0
boot system disk0:/asa981-lfbff-k8.SPA
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
 domain-name XXXXXXX
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network Airbus-Network
 subnet 10.0.0.0 255.0.0.0
object-group network DM_INLINE_NETWORK_2
 network-object 10.103.1.0 255.255.255.0
object-group network DM_INLINE_NETWORK_3
access-list AGNET-SGI_access_in extended permit ip 10.103.1.0 255.255.255.0 object Airbus-Network
access-list Corporate_access_in extended permit ip object Airbus-Network object-group DM_INLINE_NETWORK_2
access-list global_access extended permit ip any object Airbus-Network
pager lines 24
logging enable
logging asdm warnings
mtu Outside 1500
mtu AGNET-SGI 1500
mtu Corporate 1500
mtu management 1500
no failover
no monitor-interface service-module
icmp unreachable rate-limit 1 burst-size 1
icmp permit host XX.XX.XX.XX management
asdm image disk0:/asdm-781-150.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (AGNET-SGI,Corporate) source static any any destination static Airbus-Network Airbus-Network no-proxy-arp
access-group AGNET-SGI_access_in in interface AGNET-SGI
access-group Corporate_access_in in interface Corporate
access-group global_access global
route Corporate 10.0.0.0 255.0.0.0 10.38.143.246 1
route management XX.XX.XX.XX 255.255.255.255 XX.XX.XX.XX 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
http server enable
http XX.XX.XX.XX 255.255.255.255 management
snmp-server host management XX.XX.XX.XX community *****
snmp-server location XXX
snmp-server contact XXX
snmp-server community *****
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh stricthostkeycheck
ssh XX.XX.XX.XX 255.255.255.255 management
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
vpdn group Orange request dialout pppoe
vpdn group Orange localname fti/pbetyd4
vpdn group Orange ppp authentication pap
vpdn username fti/pbetyd4 password XXXXXXX
no threat-detection basic-threat
no threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server XX.XX.XX.XX source Corporate prefer
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
policy-map type inspect dns migrated_dns_map_1
 parameters
  no tcp-inspection
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:26a1ccce98f42b4412ed36d3fee54767
: end
I don't understand what's wrong.
Thanks for your help
Thanks for your answer but problem cames from my NAT rules. I have configured a previous NAT on other interface and this is this NAT rules wich is used. Problem solved by erasing all my NAT rules and redo a NAT on the correct interface.
Regards.
Jean-Yves
Jean,
 Start by adding inspect icmp on your policy-map. Just run this as presented below:
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
 If does not works, please, prove routing table for all device on the topoloy, include PCs.
Regards.
Jean-Yves
