Welcome to Cisco Firewalls Community
9819
problem with ssh access on asa
Hello All,
I have a problem with my ssh access.
I have two interfaces, 172.17.5.250 = Outside, security Level 0
                                10.11.3.2 = Inside, security Level 1
I can access by ssh using Outside
I can not access by ssh using Inside. I receive this message in my prompt:
ssh user@10.11.3.2
Selected cipher type <unknown> not supported by server.
I tried with ssh -1 and ssh -2. Not works.
I have ssh allowed for this source network. SSH version 1&2.
I tried:
ASA(config)#crypto key zeroize rsa
Issue this command in order to generate the new key:
ASA(config)# crypto key generate rsa modulus 1024
But no success
Cisco 8.2(12)2
Everyone's tags (3)
20 REPLIES 20
Advocate
Hi Diego,
can you share the output of :
show run all ssl
You should add this in your configuration:
ssl encryption rc4-sha1 aes128-sha1 aes256-sha1 3des-sha1
Refer to this dic for it:
https://supportforums.cisco.com/docs/DOC-15016
Hope this helps
Varun Rao
Security Team,
Cisco TAC
Thanks, Varun Rao Security Team, Cisco TAC
Advocate
M sorry but can youa lso post your ssh configuration?
Varun Rao
Security Team,
Cisco TAC
Advocate
One more thing that you can check is, if you have a 3DES license enabled, you can check it with "show version", ssh by default uses 3des.
Varun Rao
Security Team,
Cisco TAC
Re: problem with ssh access on asa
Varun,
I didnt see your post. I get the license and installed it, so.. I did:
1 - Get the License and Install
2 - ssl encryption aes128-sha1 3des-sha1 rc4-md5 des-sha1
But I still receive this error:
Selected cipher type not supported by server.
Hi Varun,
Look:
FW# sh run all ssl
ssl server-version any
ssl client-version any
ssl encryption des-sha1
FW# sh run all ssh
ssh 172.16.0.0 255.240.0.0 outside
ssh 192.168.41.0 255.255.255.0 outside
ssh 10.11.0.0 255.255.0.0 inside
ssh 172.16.0.0 255.240.0.0 inside
ssh 192.168.11.0 255.255.255.0 inside
ssh timeout 5
My big doubt is because when I try to connect on interface Outside, it works...
Well, I didnt do that command you sent to me yet.. Should I do?
Advocate
It is the cipher code that the client and the server exchange between them, are you using the saying client when you connect from outside? You can very well add the comand, but also check for the 3des license. If you do not have it, you can generate it from her for free:
https://tools.cisco.com/SWIFT/LicensingUI/loadDemoLicensee?FormId=139
Varun Rao
Security Team,
Cisco TAC
Varun,
I found my problem..
VPN 3DES AES isn´t enabled in my Firewall...
need a licence for ir?
Advocate
Yup I just pinged you the link above, its for free
Varun Rao
Security Team,
Cisco TAC
Varun,
Hello Diego,
Are you using the same SSH client on both interfaces?
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Julio,
Look.
Client = 172.20.65.205, connect on Outside, = OK (Windows with putty)
Client 172.19.4.40, connect on Inside, = NOK (linux with openssh-clients-4.3p2-82.el5)
Client 172.19.1.40, connect on Outise, = NOK (linux with openssh-clients-4.3p2-82.el5
Hello Diego,
what happens if you use Putty on the internal machine or any other software besides nok?
I would say it will work.
Julio
Julio Carvajal
hum... idk..
but, I can connect on SSH in another firewall without problem...
it is weird, isnt it?
Hello Diego,
I know you already did it but can you do it once :
And let me know how it goes
Julio
Julio Carvajal
Content for Community-Ad
FusionCharts will render here
