Is there a tool available to convert a Check Point Security Policy to a Cisco Access Control List?The process of doing this manually would be time consuming and could result in human error
The content you are looking for has been archived. View related content below.
HelloWe have a lot of clients getting the following error when contacting diffrent sites: ERR_SSL_PROTOCOL_ERROR, we have read that SonicWall and Palo Alto also have these problemes. Solution is to turn off "TLS 1.3 Hybridized Kyber Support" in chro...
Hello everyone,I have a CISCO ASA 5555-X configured in multi-context mode and I want to monitor it via SNMP.However, I can't find the MIB files for this device.How can I get them?I don't have access to ftp://ftp.cisco.com/pub/mibs/supportlists/asa/as...
Hello everyone, I have the following issue:The customer would like to disable FMC packet fragmentation globally. According to the Cisco documentation it is quite straightforward.Source chapter: Fragment SettingsCisco Secure Firewall Management Center...
HIWe have several Policy based VPNs, I have read in a Cisco document that the sysopt permit-vpn is not supported with Route based VPN and I will need to configure access control for this, so that being said does this affect our policy based VPNs whic...
Hi All,I am newly building trustsec in my environment,trying to add one of the switch under trustsec. Have configured Trustsec settings and COA on the ISE for the switch and added the appropriate aaa commands , radius servers and cts commands.But sti...
Hi,Please I need an advise to determine the right NGFW based on the below requirements:- Each NGFW physical appliance should provide minimum of 240 Gbps Firewall throughput.- Each NGFW physical appliance must support minimum of 850,000 new TCP connec...
Hello everybody,our customer has a FMCv running sugg. rel. 7.2.5.1 and has a high CPU load of approx. 97%.(see attached screen dump).The VM has 4 CPUs, 32GB RAM and 250GB HDD.The FMC is managing a HA of two Firepower 1120 running rel. 7.2.5.A FMC reb...
I am managing FTD-1120s with FMCv both running v7.2.1 software. In my ACP I have a GEO rule to block all outbound traffic to China, Russia, and I few other "hotspots". When I search for events that match this rule, most of the traffic is from inte...
This question has been asked a couple of other times, but no one has ever answered it. I am bringing up an AWS instance running the Cisco ASAv 9.9.2.1 application, but I am unable to ssh into the resulting instance.I am following the instructions pro...
I have an ASA on which I'm trying to use PBR to route to one of two ISPs which I'll call "slow" and "fast." The interface to the slow ISP is connected to a subnet on which the next-hop address is clearly in the subnet and it would count as "directly ...
I was looking at deploying a 3120 in multi instance mode with 4 instances but I would want each instance in a different FMC domain for different teams to manage independently. Is this possible? The only examples of multi instance I've seen put the in...
HelloWe have Cisco 1140 with FDM Management, version is 7.2.5. How do I need to configure DHCP Relay? Because I did all configuration, but int not working
Hello Experts, I have a Cisco FMC with managed Device AMP 8130 Appliance with on-premises Threat Grid and Private Cloud. I got issues about the Integration part of the FMC with TG and FMC with Private Cloud and also having trouble with TG to Privat...
Subject | Author | Posted |
04-24-2024 07:12 AM | ||
04-23-2024 11:51 PM | ||
04-22-2024 06:41 AM | ||
04-21-2024 09:36 PM | ||
04-17-2024 12:36 PM |
User | Count |
10 | |
7 | |
4 | |
4 | |
4 |
