Welcome to Cisco Firewalls Community
2372
Highlighted
Beginner
problems w/ PAT under 8.3
We have problems with 8.3 firmware on our ASA.
I try to configure pooled-dynamic-pat and it appears that it is natting properly but doesn\'t do pat but instead does pooled-nat.
According to:
https://supportforums.cisco.com/docs/DOC-9129
object network Inside_network
subnet 172.16.1.0 255.255.255.0
description internal_network_object
object network DMZ_network
subnet 172.16.0.0 255.255.255.0
description dmz_network_object
object network Inside_nat_pool
range 72.232.6.6 72.232.6.8
object network DMZ_nat_pool
range 72.232.6.9 72.232.6.11
I tried both with doule nat rule in global config:
nat (DMZ,outside) source dynamic DMZ_network DMZ_nat_pool
and also with the local (network object singleton) nat rule
nat(DMZ,outside) dynamic DMZ_nat_pool
After pool i exhausted (tried with packettracer and live servers) it returns error message saying it cannot create any new xlate and returns:
%ASA-3-305006: regular translation creation failed
Any help would be much appreciated.
1 ACCEPTED SOLUTION
Highlighted
Re: problems w/ PAT under 8.3
I think you didn't refer the sample that I added to this link:https://supportforums.cisco.com/docs/DOC-9129
All you had to do was to add all the pat addresses to the object-group. If you do an upgrade from old 8.2 config to 8.3 the upgrade will automatically do this for you.
Anyway,
Pre 8.3: (only focusing on nat id 10)
global (outside) 10 1.1.1.9
global (outside) 10 1.1.1.5
global (outside) 10 1.1.1.6
global (outside) 10 1.1.1.7
global (outside) 10 1.1.1.8
nat (Inside) 10 172.17.1.0 255.255.255.0
nat (DMZ) 10 172.17.0.0 255.255.255.0
8.3: (I am only providing the conversion for nat ID 10)
object network DMZ-network
subnet 172.17.0.0 255.255.255.0
object network inside-network
subnet 172.17.1.0 255.255.255.0
object network pat-addr-1
host 1.1.1.9
object network pat-addr-2
host 1.1.1.5
object network pat-addr-3
host 1.1.1.6
object network pat-addr-4
host 1.1.1.7
object network pat-addr-5
object-group network 5-pat-addr
network-object object pat-addr-1
network-object object  pat-addr-2
network-object object pat-addr-3
network-object object pat-addr-4
network-object objec pat-addr-5
nat (DMZ,outside) dynamic 5-pat-addr
nat (inside,outside) dynamic 5-pat-addr
-KS
12 REPLIES 12
Highlighted
That link is talking about
Pre 8.3
 nat (inside) 1 10.1.2.0 255.255.255.0
global (outside) 1 interface
global (outside) 1 192.168.100.100-192.168.100.200
8.3:
 object network obj-192.168.100.100_192.168.100.200
   range 192.168.100.100 192.168.100.200
object network obj-10.1.2.0
   subnet 10.1.2.0 255.255.255.0
   nat (inside,outside) dynamic obj-192.168.100.100_192.168.100.200 interface
But that is not what you have.
Can you try
nat(DMZ,outside) dynamic DMZ_nat_pool interface
Dont' miss my ATE event: https://supportforums.cisco.com/community/netpro/ask-the-expert
-KS
Highlighted
Beginner
We are talking about the same thing so please accept my update on this matter:
I did try what you suggested and the result is the same. It is not creating pat-pool over few addresses.
WIth interface keyword it creates a pat over one address (of external IF) and then 1-1 nat pool of the pool object group specified in nat command:
NAT from DMZ:172.16.0.102 to outside:1.1.1.10 flags i idle 0:00:40 timeout 3:00:00
NAT from DMZ:172.16.0.101 to outside:1.1.1.9 flags i idle 0:00:48 timeout 3:00:00
UDP PAT from DMZ:172.16.0.163/41364 to outside:1.1.1.2/64950 flags ri idle 0:00:01 timeout 0:00:30
1.1.1.2 is external interface
.9 and .10 are in the DMZ_nat_pool object range
When pool gets exhausted by either packet tracer and or real hosts it cannot create any new translations.
When dynamic pat over pool is configured it is not attempting to use the pat anymore It does nat only for the number of hosts that are in the pool and then stops giving error message.
There was also another nat rule with twice-nat so I added it in front of everything:
nat (DMZ,outside) 1 source dynamic DMZ_network DMZ_nat_pool
That didn't help too.
I did try using 'interface' keyword that you suggested but also no luck.
Do I have to reload the box or do anything else than 'clear xlate' to be effective.
I did try deleting DMZ_nat_pool and DMZ_network objects and re-creating them. No luck
When looking at the debug there is a message:
nat: WARNING - alloc socket in pool -1401456072 failed, prot 17/0, DMZ:172.16.0.5/54435 to outside
As a another idea I tried to do multiple host like mappings for outside traffic hoping it will start doing pat over pool properly.
dfw-prod-asa-01(config)# object network obj_100
dfw-prod-asa-01(config-network-object)# host 1.1.1.100
dfw-prod-asa-01(config-network-object)# exit
dfw-prod-asa-01(config)# object network obj_101
dfw-prod-asa-01(config-network-object)# host 1.1.1.101
dfw-prod-asa-01(config)# nat (DMZ,outside) source dynamic DMZ_network obj_100
dfw-prod-asa-01(config)# nat (DMZ,outside) source dynamic DMZ_network obj_101
WARNING: Pool (1.1.1.101) overlap with existing pool.
When pool is exhausted any new packet generated is giving such error:
dfw-prod-asa-01(config)# packet-tracer input DMZ icmp 172.16.0.211 0 0 8.8.8.8
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         outside
Phase: 2
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 3
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect icmp
service-policy global_policy global
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 5
Type: DEBUG-ICMP
Subtype:
Result: ALLOW
Config:
Phase: 6
Type: NAT
Subtype:
Result: DROP
Config:
nat (DMZ,outside) source dynamic DMZ_network DMZ_nat_pool interface
Result:
input-interface: DMZ
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Any ideas?
Has anyone seen this behaviour before?
dfw-prod-asa-01(config)# show ver
Cisco Adaptive Security Appliance Software Version 8.3(2)
Device Manager Version 6.2(1)
Compiled on Fri 30-Jul-10 17:49 by builders
System image file is "disk0:/asa832-k8.bin"
Config file at boot was "startup-config"
dfw-prod-asa-01 up 2 days 20 hours
failover cluster up 9 days 10 hours
Hardware:   ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1599 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW016 @ 0xfff00000, 2048KB
MB
Highlighted
Pls. remove this line:
Pls. only use what I had mentioned earlier which is below and see if it works.
-KS
Highlighted
Beginner
As I mentioned it does not work as intended.
Outside communication is possible but the PAT is only occuring using the external interface IP address (.2) and not the whole pool.
Using your config:
send 4 pings:
2 executed exhausted the DMZ_nat_pool
then it started PAT over external IP address while it should do PAT over all the IPs from DMZ_nat_pool.
show xlate
ICMP PAT from DMZ:172.16.0.165/38958 to outside:1.1.1.2/54843 flags ri idle 0:00:26 timeout 0:00:30
NAT from DMZ:172.16.0.10 to outside:1.1.1.10 flags i idle 0:02:00 timeout 3:00:00
NAT from DMZ:172.16.0.101 to outside:1.1.1.9 flags i idle 0:01:54 timeout 3:00:00
ICMP PAT from DMZ:172.16.0.163/18493 to outside:1.1.1.2/8051 flags ri idle 0:00:02 timeout 0:00:30
Config:
     range 1.1.1.9 1.1.1.10
nat (DMZ,outside) dynamic DMZ_nat_pool interface
Can you try to reproduce this error?
MB
Highlighted
I think it is working as expected.
When  the range gets exhaused (DMZ_nat_pool) it is using the interface for PAT. That is what the above command is supposed to do and is doing.
I see both NAT and PAT in the ouput that you posted above. For ICMP and dynamic NAT - I'd enable icmp inspection.
I am not clear as to what you are explaining as incorrect behavior.
-KS
Highlighted
Beginner
Just to clarify. What you have is nat + masquerade pat. We want to do pat over multiple IPs and apparently this is immposible with 8.3(2)
Highlighted
nat pool and interface PAT for the DMZ network:
Second PAT in addition to the above for the same DMZ network:
object network DMZ_network_1
object network second-pat
  host 1.1.1.x
object-group network dyn-nat-pat
     network-object object DMZ_nat_pool
     network-object object second-pat
  nat(DMZ,outside) dynamic dyn-nat-pat interface
I have added the above as an example in this link: https://supportforums.cisco.com/docs/DOC-9129
under NAT & Interface PAT with additional PAT together.
-KS
Highlighted
Beginner
I still think we are not on the same page.
I just want to do this and from the traffic and nat table I am unable to do so. I don't need pooled nat but rather a pooled PAT meaning any given host from inside/dmz will be portmaped with the IP from the pool. So in the theory I might have POOL_MEMBERS * 64000 number of connections.
When your config is activated first what is happening is any DMZ host is taking one-by-one members of the pool and because timeout of xlate is longer (3hrs) it stays there in xlate table. Any new connection is then PATed to single IP of .2 with shorter xlate timeout (30s). Essentially this reduces number of connections to only 64000.
show xlate when trying different hosts from DMZ:
TCP PAT from DMZ:172.16.0.121/8213 to outside:72.232.6.2/33144 flags ri idle 0:00:10 timeout 0:00:30
NAT from DMZ:172.16.0.10 to outside:72.232.6.10 flags i idle 0:01:21 timeout 3:00:00
TCP PAT from DMZ:172.16.0.123/8213 to outside:72.232.6.2/33114 flags ri idle 0:00:05 timeout 0:00:30
NAT from DMZ:172.16.0.11 to outside:72.232.6.9 flags i idle 0:01:10 timeout 3:00:00
TCP PAT from DMZ:172.16.0.120/8213 to outside:72.232.6.2/7174 flags ri idle 0:00:15 timeout 0:00:30
pre 8.3 config
---snip---
global (outside) 5 12.2.2.33
nat (DMZ) 5 access-list acl_outside_1
---snip---
Can you create a PAT pool under 8.3(2) that would reflect the above config?
MB
Highlighted
Anyway,
host 1.1.1.9
host 1.1.1.5
host 1.1.1.6
host 1.1.1.7
-KS
Highlighted
Beginner
Thank you!
That worked perfectly.
Highlighted
Glad to hear.  Thanks for rating. Pls. consider marking this thread answered as well.
-KS
Highlighted
Beginner
I think best course of action is to open a case with cisco.
Sent from Iphone
On Dec 24, 2010, at 9:04 AM, "michal.bicz"
Content for Community-Ad
FusionCharts will render here
