Welcome to Cisco Firewalls Community
223
Beginner
Reimage from FTD 5525-x to ASA
Once you reimage to FTD on the 5525-x can you reimage back to ASA or is it a one way path?
Adam
1 REPLY 1
Hall of Fame Master
Re: Reimage from FTD 5525-x to ASA
You can revert to the ASA image. You need to have access to the console port as it is done from the rommon prompt.
Details for how to do so are described here:
https://www.cisco.com/c/en/us/td/docs/security/firepower/quick_start/reimage/asa-ftd-reimage.html#id_57458
