Routing problem between C3560 and ASA
sysadmin
I'm new to firewalls, so apologies if i'm wrong anhywhere.
Here is my setup.
I have a cisco C3560 switch with multiple VLans
It is connected to ASA 5505 which is further connected to Internet.
C3560 <--> G0/46 <--> 10.40.250.2 <--> 10.40.250.1 <--> E0/1 <--> ASA 5505
My problem is I'm not able to ping internet hosts from switch. Reverse route is fine. I'm able to ping switch and hosts on other Vlans.
And from switch I'm able to ping 10.40.250.1 (ASA interface). But from switch or my desktop i'm not able to go to internet.
Following are my configurations. Kindly help.
ASA Configuration
<code>
ASA Version 8.2(2)
hostname sg-fw2
names
interface Ethernet0/0
nameif OUTSIDE
security-level 0
ip address dhcp setroute
interface Ethernet0/1
nameif INSIDE
security-level 100
ip address 10.40.250.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object-group network INTERNAL_RANGE
pager lines 24
logging enable
logging asdm informational
logging mail critical
mtu OUTSIDE 1500
mtu INSIDE 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
router eigrp 321
no auto-summary
default-metric 100000 1 255 1 1500
network 0.0.0.0 0.0.0.0
redistribute static
route INSIDE 10.40.0.0 255.255.0.0 10.40.250.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 10.40.0.0 255.255.0.0 INSIDE
snmp-server host INSIDE 10.40.12.210 poll community ***** version 2c
no snmp-server location
no snmp-server contact
snmp-server community *****
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 10.40.0.0 255.255.0.0 INSIDE
ssh timeout 5
ssh version 2
console timeout 0
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect http
  inspect icmp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:3b4c6840cb9a7b2b490bcc2574f65371
: end
</code>
C3560 Swittch Configuration
<code>
Building configuration...
Current configuration : 10370 bytes
! Last configuration change at 19:05:13 WST Sat Nov 2 2013 by sysadmin
version 15.0
no service pad
no service timestamps debug uptime
service timestamps log datetime
service password-encryption
service sequence-numbers
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone WST 8 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
system mtu routing 1500
ip routing
ip dhcp snooping vlan 522
ip dhcp snooping
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause vmps
errdisable recovery cause storm-control
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
spanning-tree mode pvst
spanning-tree vlan 1-999 priority 24576
vlan internal allocation policy ascending
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface Port-channel1
switchport mode trunk
interface GigabitEthernet0/1
switchport access vlan 522
switchport mode access
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
switchport access vlan 512
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
switchport access vlan 523
interface GigabitEthernet0/18
description trunk to bm-sg-sw3 in other server room
interface GigabitEthernet0/19
description link to 3com switch for 10.40.12.x network
ip dhcp snooping trust
interface GigabitEthernet0/20
description link to drac card on xen server
mls qos trust cos
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
description servers in engineering room
mls qos trust cos
interface GigabitEthernet0/34
description link to rack for engineering network
mls qos trust cos
interface GigabitEthernet0/35
description C1841-F0/1
switchport access vlan 600
spanning-tree portfast
interface GigabitEthernet0/36
description ASA5510-F0/1
mls qos trust cos
interface GigabitEthernet0/37
description C2811-F0/0
mls qos trust cos
interface GigabitEthernet0/38
description vmserver1
interface GigabitEthernet0/39
interface GigabitEthernet0/40
description build server nas
interface GigabitEthernet0/41
description server farm b
interface GigabitEthernet0/42
mls qos trust cos
interface GigabitEthernet0/43
description hub for engineering server farm
interface GigabitEthernet0/44
description connection for voip 2851
no switchport
ip address 10.40.40.1 255.255.255.0
interface GigabitEthernet0/45
no switchport
no ip address
interface GigabitEthernet0/46
description connection to ASA inside
no switchport
ip address 10.40.250.2 255.255.255.0
duplex full
interface GigabitEthernet0/47
description span port
interface GigabitEthernet0/48
interface GigabitEthernet0/49
description trunk to 3560-POE switch 2
channel-group 1 mode desirable
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
ip address 10.10.100.1 255.255.255.0
interface Vlan10
ip address 10.40.10.3 255.255.255.0
interface Vlan300
ip address 10.40.255.1 255.255.255.248
interface Vlan512
description corp_serv
ip address 10.40.12.1 255.255.255.0
interface Vlan520
description corp_con
ip address 10.40.200.1 255.255.254.0
interface Vlan522
description workstations
ip address 10.40.224.1 255.255.254.0 secondary
ip address 10.40.220.1 255.255.254.0
ip helper-address 10.40.12.253
ip helper-address 10.40.12.252
interface Vlan523
description office_lab
ip address 10.40.230.1 255.255.254.0
ip access-group vlan523_access_in in
no ip unreachables
router eigrp 321
network 3.0.0.0
network 10.0.0.0
eigrp stub connected summary
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.40.250.1
ip route 10.1.0.0 255.255.0.0 10.40.10.254
ip route 10.1.1.0 255.255.255.0 10.40.250.1
ip route 10.40.240.0 255.255.254.0 10.40.40.2
ip route 202.56.195.121 255.255.255.255 10.40.10.254
ip route 202.152.162.174 255.255.255.255 10.40.10.254
ip route 202.152.162.177 255.255.255.255 10.40.10.254
ip route 203.145.131.152 255.255.255.255 10.40.10.254
ip route 203.196.249.7 255.255.255.255 10.40.10.254
ip access-list extended search_for_192.168
permit ip any host 216.246.60.14 log-input
ip access-list extended vlan523_access_in
remark permit any tcp connection into this vlan to return
permit tcp any any established
remark allow DNS query
permit udp any host 10.40.12.253 eq domain
remark http access to fumes
permit tcp any host 10.26.156.51 eq www
permit tcp any host 10.26.156.51 eq 443
remark http access to 3.0 build machine
permit tcp any host 10.26.156.30 eq www
permit tcp any host 10.26.156.30 eq 443
remark allow communication between 10.40.231.205 and cisco cme
permit ip host 10.40.231.205 host 10.40.240.1
permit ip host 10.40.231.205 host 10.40.40.2
remark Allow IANA ephemeral port
permit udp any any range 49152 65535
permit udp any any range 25000 35000
permit udp any any range 40001 45000
remark permit connection to SingNet Proxy
permit tcp any host 220.255.4.9 eq 8080
remark http and NFS access to filesvr
permit tcp any host 10.40.12.248 eq www
permit tcp any host 10.40.12.248 eq 443
permit tcp any host 10.40.12.248 eq sunrpc
permit udp any host 10.40.12.248 eq sunrpc
permit tcp any host 10.40.12.248 eq 2049
permit udp any host 10.40.12.248 eq 2049
permit tcp any host 10.40.12.248 range 4000 4002
permit udp any host 10.40.12.248 range 4000 4002
remark permit sip traffic
permit tcp any any range 5060 5063
permit udp any any range 5060 5063
permit udp any any range 5000 5003
permit udp any any range 5010 5013
permit udp any any range 16384 32767
remark permit access to ldap server
permit tcp any host 10.40.12.247 eq 389
deny   icmp any any redirect
deny   icmp any any mask-request
permit icmp any any
permit ip 0.0.0.0 255.255.254.0 0.0.0.0 255.255.254.0
permit tcp 0.0.0.0 255.255.254.0 0.0.0.0 255.255.254.0
permit ip any any
permit tcp any any
logging trap warnings
logging facility syslog
logging source-interface Loopback0
logging host 10.40.12.210
line con 0
logging synchronous
line vty 0 4
privilege level 15
password 7 120F0B0F1F08545D79
transport preferred none
transport input telnet
transport output none
line vty 5 15
privilege level 15
monitor session 1 source vlan 1 - 4094
monitor session 1 destination interface Gi0/47
ntp server 10.40.12.253 prefer
end
</code>
Jouni Forss
Seems you have posted the same thread twice (they probably moved your threads to this section from some other section)
So postin same reply here as in the other thread
The ASA is lacking NAT configurations.
You can do the basic Dynamic PAT translation with either of the below ways
global (OUTSIDE) 1 interface
nat (INSIDE) 1 0.0.0.0 0.0.0.0
nat (INSIDE) 1 10.0.0.0 255.0.0.0
Hope this helps
- Jouni
- Jouni
Jouni Forss
Hope this helps
- Jouni
- Jouni
