11-26-2014 06:56 AM - edited 03-11-2019 10:08 PM
I am trying to mainatain a 5505 firewall from my office Mac OSX, using the ASDM java application.
However, it refuses to run after I upgraded to the latest OSX version 10.10.1 (Yosemite)
When activating it the system says I need to get the Java Runtime Environment for Web Start-program.
I have installed the latest version ( version 8 from Oracle) but there is no change, I still get the same message.
Any suggestions how to solve this is appreciated.
BN
11-26-2014 09:02 AM
For OS X 10.10 you need:
12-01-2014 12:46 AM
Thanks, I got further with your advice, but not there yet.
I got the device login window, but there it got stuck.
Here is the console output:
Using JRE version 1.8.0_25 Java HotSpot(TM) 64-Bit Server VM
User home directory = /Users/bnilsson
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
m: print memory usage
q: hide console
s: dump system properties
Application Logging Started at Mon Dec 01 09:41:57 CET 2014
Local Launcher Version = 1.5.50
Local Launcher Version Display = 1.5(50)
OK button clicked
Trying for ASDM Version file; url = https://129.16.138.205/admin/
Server Version = 6.4(5)
Server Launcher Version = 1.5.50, size = 453120 bytes
invoking SGZ Loader..
Cache location = /Users/bnilsson/.asdm/cache
Exception in thread "SGZ Loader: launchSgzApplet" java.lang.ExceptionInInitializerError
at dkb.a(Unknown Source)
at dkb.updateUI(Unknown Source)
at dcm.updateUI(Unknown Source)
at javax.swing.text.JTextComponent.<init>(JTextComponent.java:312)
at javax.swing.JTextArea.<init>(JTextArea.java:204)
at javax.swing.JTextArea.<init>(JTextArea.java:150)
at dkb.<init>(Unknown Source)
at dcm.<init>(Unknown Source)
at c9y.c(Unknown Source)
at ee.e(ee.java:171)
at ee.c(ee.java:153)
at ee.a(ee.java:137)
at a6g.a(a6g.java:39)
at a59.<clinit>(a59.java:70)
at pv.a(pv.java:350)
at pv.<init>(pv.java:264)
at com.cisco.pdm.PDMApplet.start(PDMApplet.java:160)
at com.cisco.nm.dice.loader.r.run(DashoA19*..:410)
Caused by: java.lang.ClassCastException: java.util.HashMap cannot be cast to java.awt.RenderingHints
at dj3.<clinit>(Unknown Source)
... 18 more
12-01-2014 12:59 AM
Have you also tried the JDK instead of the JRE? And you should update the ASDM to a recent version like 7.3.1.101
12-01-2014 01:15 AM
I have installed both JDK and JRE and I don't know how to select between them since I open https:// and press the "Run ASDM". Then what happens happens.
My ASDM version is 6.4(5).
To upgrade, I need a support contract with cisco, which I don't have.
12-01-2014 02:09 AM
I am arranging a support contract now.
11-24-2015 05:13 AM
I had tried but did not executed ... now using window os with java 6...
11-24-2015 05:11 AM
Hi Friends
I have tried it serverl times but not able to login with java 8..
Would be possible with Java 6..
ASDM manger not working with mac os x 10.10
11-24-2015 05:11 AM
what exactly doesn't work?
04-08-2015 07:55 AM
I had the same problem as the original poster, and installing JDK (version 8) solved the issue.
