10-07-2015 07:06 PM - edited 03-11-2019 11:42 PM
Is there a way I can have 2 ports, say gi 0/0 and gi 0/1 on the same segment on the 5585? Obviously, 1 of the interface will have an IP address while the other will not. This is similar to interface vlan xx and assigning vlan to a port in the 5505. I need to connect to hosts that are on the same subnet to the firewall and want to do it without using a switch.
Thanks!
10-07-2015 08:12 PM
Not really. Only the 5505 supported switchports.
All other ASA models can do things like redundant interfaces, Etherchannels, subinterfaces etc. But not switchports.
I think I understand what you're asking but the use case isn't apparent. You want to use a $100,000 firewall like a $500 switch?
10-08-2015 04:36 PM
Well, I have 30 ports on the firewall and only a couple was used. So I have plenty of ports. The devices that need to connect to firewall are in the next cabinet, while the switch is in a rack 2 rows away.
