Site to site VPN using 501 PIX
woods8
I am a newcomer to cisco pixs and I am trying to setup an ipsec vpn between 2 sites. I cant seem to get the vpn tunnel up? Attached are the 2 configs.
Any advice would be very much appreciated.
Thanks in advance.
t-heeter
A small topology diagram would help. Here's a starter.
Site A Pix needs
nat (inside) 0 access-list 100
Site B Pix
crypto map newmap 40 match address 140, NOT 150, access-list 150 does not exist
ajagadee
Paul,
On FORUM SitA Pix, add the below lines to the configuration.
nat(inside) 0 access-list 100
On FORUM SitB Pix, reconfigure the match address from
crypto map newmap 40 match address 150
To
And if you want to allow FORUM Site B users to have internet access, then you need to configured NAT for NATTing all internet traffic and NAT 0 to bypass NAT for IPSEC Traffic.
For example:
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
After you make the above configuration changes, do a clear xlate, clear cry is sa and clear cry ipsec sa and then bring up the tunnel.
Let me know how it goes.
I hope it helps.
Arul
** Please rate all helpful posts **
jmia
Level 7
Level 7
Take a look at the following document - very good to get you going:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080094761.shtml
Hope this helps and please rate posts!
