Solved: VPN S2S/L2L between 2 ASA 5505 Packet tracer
MrEtho53
Hello, I'm new in the community of packet tracer.
I am trying to create a VPN between 2 Cisco ASA 5505 (Site to site) via packet tracer.
I would like my PC from my Site 1 (192.168.1.1) to ping my 2nd PC from my Site 2 (192.168.2.1)
Unfortunately if I send a ping from my PC 1 (192.168.1.1) the ASA 5505 site 2 (10.10.10.2) blocks my package
I tried to follow different tutorial found on the net but none gives a positive result.
regards.
ASA0 configuration
ASA Version 8.4(2)
hostname ASAVevey
names
interface Ethernet0/0
interface Ethernet0/1
 switchport access vlan 2
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.1.2 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 10.10.10.1 255.255.255.0
object network LAN-inside
 subnet 192.168.1.0 255.255.255.0
route outside 192.168.2.0 255.255.255.0 10.10.10.2 1
access-list ACL1 extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list outside extended permit icmp any any
access-group outside out interface outside
 nat (inside,outside) dynamic interface
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect icmp
telnet timeout 5
ssh timeout 5
dhcpd auto_config outside
dhcpd enable inside
crypto ipsec ikev1 transform-set myset esp-aes esp-sha-hmac
crypto map cmap 1 match address ACL1
crypto map cmap 1 set peer 10.10.10.2
crypto map cmap 1 set ikev1 transform-set myset
crypto map cmap interface outside
crypto ikev1 enable outside
crypto ikev1 policy 1
 encr aes
 authentication pre-share
 group 2
tunnel-group 10.10.10.2 type ipsec-l2l
tunnel-group 10.10.10.2 ipsec-attributes
 ikev1 pre-shared-key cisco123
ASA1 configuration
ASA Version 8.4(2)
hostname ASALausanne
names
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.2.2 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 10.10.10.2 255.255.255.0
 subnet 192.168.2.0 255.255.255.0
route outside 192.168.1.0 255.255.255.0 10.10.10.1 1
access-list ACL2 extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
  inspect icmp
telnet timeout 5
ssh timeout 5
dhcpd enable inside
crypto map cmap 1 match address ACL2
crypto map cmap 1 set peer 10.10.10.1
 encr aes
 group 2
tunnel-group 10.10.10.1 type ipsec-l2l
tunnel-group 10.10.10.1 ipsec-attributes
Hello @MrEtho53,
There is no alternative in Packet-Tracer that´s what you get, nothing else. I would suggest using GNS3 or EVE-NG (better option) for your labs.
Unfortunately, Packet-tracer is very limited in Firewalling.
Gio
Bogdan Nita
It seems you are nating the vpn packets, that will cause not to match the crypto-acl.
In order to avoid that you can configure identity nat for the vpn traffic. Should be something like:
ASA0 configuration:
object network LAN-remote
nat (inside,outside) source static LAN-inside LAN-inside destination static LAN-remote LAN-remote no-proxy-arp route-lookup
ASA1 configuration:
Bogdan
Thank you very much for your answer, unfortunately in packet tracer my Firewall ASA 5505 doesn't have the nat command in "(config) #".
So what can I do in alternative?
See it below:
A big thanks.
ASAVevey(config)#?
  aaa             Enable, disable, or view user authentication, authorization
                  and accounting
  access-group    Bind an access-list to an interface to filter traffic
  access-list     Configure an access control element
  boot            Set system boot parameters
  class-map       Configure MPF Class Map
  clock           Configure time-of-day clock
  configure       Configure using various methods
  crypto          Configure IPSec, ISAKMP, Certification, authority, key
  dhcpd           Configure DHCP Server
  domain-name     Change domain name
  enable          Configure password for the enable command
  end             Exit from configure mode
  exit            Exit from configure mode
  group-policy    Configure or remove a group policy
  hostname        Change host name of the system
  http            Configure http server and https related commands
  interface       Select an interface to configure
  ipv6            Global IPv6 configuration commands
  name            Associate a name with an IP address
  names           Enable/Disable IP address to name mapping
  no              Negate a command or set its defaults
  ntp             Configure NTP
  object          Configure an object
  object-group    Create an object group for use in 'access-list', etc
  passwd          Change Telnet console access password
  policy-map      Configure MPF Parameter Map
  route           Configure a static route for an interface
  service-policy  Configure MPF service policy
  setup           Pre-configure the system
  ssh             Configure SSH options
  telnet          Add telnet access to system console or set idle timeout
  tunnel-group    Create and manage the database of connection specific records
                  for IPSec connections
  username        Configure user authentication local database
  webvpn          Configure the WebVPN service
Hello @MrEtho53,
Gio
Considering it is a lab and you want to test the vpn, you could remove the nat config.
 no nat (inside,outside) dynamic interface
