Static NAT, inbound traffic permitted by default?
tonny_ecmyy
Hi, I have a simple question here, regarding the static nat, suppose that webserver is 192.168.1.2 and public ip 200.200.200.202
static (inside,ouside) 200.200.200.202 192.168.1.2 netmask 255.255.255.255
and there is no access-list to permit inbound tcp port 80, but there is sigle access-list permy ip any any inside the config,
can outside user reach the webserver? because i saw my customer's config, it works without applying eg. access-list inbound permit tcp any host 200.200.200.202 eq 80
6 Replies 6
a.kiprawih
Level 7
Level 7
It should work as it permit everything (any IP) from internet to the internal network - not limited to whatever specified IP via the permitted port.
This is not recommended from security point of view as if possible, you should only permit access to known/specific internal server mapped with specific Public IP, not any IP.
Best practise (recommended) is to specify specific destination address and tcp/udp port, or for common server/services, i.e webserver, you can permit any IP but to specific server via specific TCP/UDP port only.
AK
AK
ok thanks, please confirm whether the following config is secure
access-list inbound permit tcp any host eq 80
access-list inbound deny ip any any
access-list inbound permit ip any any
another question is, are there any impact if we apply permit ip any any? because if dont apply it, all the traffic stop. From my opinion, permit ip any any is important if we have apply ACLs inbound permit tcp any host eq 80,
if permit ip any any is working alone without permit tcp 80, then it open all the inbound connections. correct me if i'm wrong.
thanks
opps missing ip there
access-list inbound permit ip any any ---> remove this, not required as conflict with the 2nd acl (access-list inbound deny ip any any)
The ACL is only permitting any outside IPs to access 200.200.200.202 via www/80.
But this will deny ALL other IPs and services. Looks not good unless if you really want outsiders to only access 200.200.200.202 for web services.
If you have other services and need to allow any IPs from outside/internet, pls identify the servers and mapped with public IP. Allow inbound access simialr to the 200.200.200.202 rule. Can you specify any?
AK
for the 3rd acl, if not specify access-list inbound permit ip any any , can other traffic that we permitted pass through? public ip 200.200.200.202 is for web server only, no other services allowed. actually, there are 12 web servers here, 1 mail server. Now i'm confuse about permit ip any any, if not apply it, the traffic that i've permitted will stop.
No, because the second acl already denied everything. Any permit statement will completely be ignored.
Same if your permit any comes before deny any, it will permit ALL, and will ignore the deny statement.
HTH. Pls rate all useful post(s)
AK
