Stopping Scrolling on ASA - Ctrl-Shft-6 Not Working
rafrancis
Could someone let me know the break to stop scrolling in config mode on the ASA when I am debugging or looking at a capture?  I tried Ctrl-Shft-6 (routers only) but that did not work.  It just seems quite annoying that I have to press "more" to get to the bottom before I can veiw anything.
If you do a show run for example and you want to exit back to the screen instead of pressing the space-bar to reach the end of the output just press the q (quit) key.
Hope it helps.
Federico.
