05-20-2008 10:37 AM - edited 03-11-2019 05:47 AM
I have a customer that runs large oracle queries (1521)that the PIX sees as idle connections. I've tried classifying the traffic and using polic-maps to set the connection to not timeout (0:0:0) with no luck. Any suggestions?
Solved! Go to Solution.
05-26-2008 01:23 PM
Can you provide more information about the issue you are facing and also the output of "show tech" which will help us in finding a better solution after identifying the cause of the issue.
05-26-2008 01:23 PM
05-26-2008 04:07 PM
Thanks for the reply, it was a bug in code that was fixed in a later version.
Again Thanks!
