Throughput issues in Cisco ASA 5510
VAbr AVib
For internet connectivity, we have a Cisco Firewall connected to a BGP router multihomed with 2 ISP. Attached the high level diagram for reference.
We have noticed that the bandwidth usage over the primary connectivity is less than 5 % of the total 100 mbps internet bandwidth, same way if i route the traffic via the secondary path then the bandwidth goes at an average up to 30 %.
I have noticed that if i use any fast download softwares like DAP, then i am getting a speed of almost 10 Mbps but the normal usage is not crossing 5%. Is there any settings in ASA that i have to do to make this primary interface use more bandwidth.
VAbr AVib
It looks like only the http traffic that is not giving the throughput, the VPN and all other traffic is perfectly working. Also as i mentioned earlier if we use a Download Accelerator then i can easily download with 10 Mbps speed.
Any idea is this behavior due to any inspection ?
Please check the below configuration, any idea will this impact the internet browsing and download rate.
class-map netflow-export-class
match access-list netflow-export
class-map inspection_default
match default-inspection-traffic
class-map http-port
match port tcp eq www
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect sip
  inspect ftp
  inspect ip-options
class netflow-export-class
class class-default
  flow-export event-type all destination 10.10.10.21
policy-map type inspect http inbound_http
parameters
match request body length gt 2000
  reset log
match response body length gt 2000
  reset log
match not request body length gt 100
  reset log
match not response body length gt 100
  reset log
match req-resp content-type mismatch
  reset log
match request header content-type violation
  reset log
match response header content-type violation
  reset log
match request header length gt 100
  reset log
match request uri length gt 100
  reset log
class _default_gator
  drop-connection
class _default_kazaa
  drop-connection
class _default_msn-messenger
  drop-connection
class _default_aim-messenger
  drop-connection
class _default_yahoo-messenger
  drop-connection
policy-map inbound_policy
class http-port
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
