Throughput on Network hardware
ajay kondapalli
Hi ,
Can any one explain me what is exactly " Throughput " which is referred in Network devices hardware comparisons.  Is this something the rate which the devices send the data per second ?  For example,  if We see Firewall throughput on ASA5520  is 450Mbps  , what does it mean ?
How can we interpret and understand this !
Ajay
Aditya Ganjoo
Hi Ajay,
Yes you are right.
For Calculating Throughput on the ASA,  We have to add received or Transmit  traffic in bytes/sec on all physical interfaces.
You need to check the "show traffic" output
on the: Aggregated Traffic on Physical Interface
grab the receive pkts/sec plus the transmited pkts/sec of all the physical interfaces.
Now divide it by 1024 to get kilobytes and then divide it again by 1024 to get megabytes/sec.
Aditya
Please rate helpful posts.
