Welcome to Cisco Firewalls Community
315
Contributor
Traceroute through ASA?
If traceroute is done lets say some far away host out in the WAN, the trace will stop showing anything once it hits a FW that is blocking it correct? Meaning, It won't just show the * but then show all IPs of the hops after it that aren't FWs?
2 ACCEPTED SOLUTIONS
RJI Advisor
Advisor
Re: Traceroute through ASA?
If you traceroute through the ASA, as default the ASA will not appear as a hop (unless you specify to decrement-ttl). In order for every hop on the outside of the ASA to be displayed you'd specifically need to permit that traffic. To permit traceroute traffic you'd modify your inbound ACL on the outside interface to permit time-exceeded and unreachable (it depends on which OS the traceroute was sent as to which is required).
VIP Advocate
No,
You need to allow ICMP but set connection decrement-ttl is only if you want the ASA to be seen in the traceroute path.  If you want the ASA to remain invisible do not implement this.  It is not good practice to implement it and should only be done if you have a specific need to do so.
Please remember to rate and select a correct answer
4 REPLIES 4
RJI Advisor
Advisor
Contributor
Ok so I should allow ICMP as well as class class-default
set connection decrement-ttl?
VIP Advocate
No,
VIP Advocate
To allow trace route through the firewall you need to implement the following commands:
policy-map global_policy
  class inspection_default
  inspect icmp
  inspect icmp error
access-list outside_access_in extended permit icmp any any unreachable
access-list outside_access_in extended permit icmp any any time-exceeded
As @RJI has already mentioned, if you want the ASA to be seen as a hop along the traceroute path you need to configure the ASA to decrement the TTL counter.
  class class-default
Content for Community-Ad
FusionCharts will render here
