Traffic being rejected by ASA 5505
davealessi
                   I recently began having issues with customer traffic being rejected by my ASA.  I wasn't really aware of it until it becme critical.
I looked at the asa 5505 log today and saw a message as follows:
4Dec 04 201308:03:2045000172.15.235.11Deny traffic for protocol 6 src outside:173.165.205.241/6588 dst inside:72.15.235.11/443, licensed host limit of 10 exceeded.
What does this mean?  I am not aware of any license restrictions on the box.
I am also seeing another deny message but I don;t understand it.
4Dec 04 201308:03:1710602395.76.86.22672.15.235.1Deny tcp src outside:95.76.86.226/1227 dst outside:72.15.235.1/445 by access-group "outside_access_in" [0x0, 0x0]
My issue has gone critical.  Any guideance would be appreciated.
Jouni Forss
The first log message seems to indicate that the ASA5505 Licensed host limit has been reached.
The ASA5505 to my understanding has atleast 3 different levels of host licensing.
  • 10 users
  • 50 users
  • Unlimited Users
And of those to my understanding the 10 user limit is for the Base License unit, 50 user limit is sold separately for a Base License (or as a bundle) unit and Unlimited is either sold separately for a Base License unit (or as a bundle) or is included with a Security Plus license of the unit. I am not 100% sure about this but that is how I remember it.
The user licensing should work so that the hosts behind the interface holding the Default Route arent considered/counted towards this limit. Only users on your LAN interface or DMZ interface are counted towards this limit.
You should check the following commands output to get a clearer information of the current situation
View the license with
show version
Show the amount of users counted towards the license limit
show local-host
Look at the top part of the output.
Here is an example from my own home ASA5505 with Base License only
ASA# sh local-host
Detected interface 'WAN' as the Internet interface. Host limit applies to all other interfaces.
Current host count: 3, towards licensed host limit of: 10
There is also some bugs in the newer softwares that might cause problems even though the user limit is not reached.
The second log message you posted is simply the ASA denying traffic based on your ACL called "outside_access_in"
The [0x0, 0x0] at the end indicates that the traffic hits the Implicit Deny rule at the end. This rule doesnt show in the ACL but is the basic well known rule that means that all traffic that is not allowed in the ACL before the end of the ACL is blocked.
I dont see anything out of the ordinary in the log message.
But as I said the first one seems to indicate that you have reached the 10 user limit which would indicate you have a basic ASA5505 with Base License only
Have a look at this Cisco document about the ASA5505 Licensing/Bundle options
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps6120/prod_brochure0900aecd80402e36.html
Hope this helps
Please do remember to mark a reply as the correct answer if it answered your question.
Feel free to ask more if needed
- Jouni
Julio Carvajal
Basically you have an ASA 5505 where by default you will only be able to support up to 10 different hosts on the internal network to innitiate traffic to the lower security level interface.
You can upgrade the license to 50 or to unlimitted users.
(You could aso use a proxy and bypass the license restriction)
This one talks about a connection being denied by the access-list applied on the outside interface
Rate all of the helpful posts!!!
Jcarvaja
Follow me on http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
