Showing results forĀ
Search instead forĀ
Did you mean:Ā
UDP connection for OUTSIDE to OUTSIDE
Shuja Tirmizi
I just reboot my both firewalls connected as active/failover mode, some of the devices were not establishing the connection. when I checked the fire wall I notice these connection using same source and destination interface OUTSIDE.
UDP OUTSIDE  10.2.11.1:162 OUTSIDE  10.5.100.93:51046, idle 0:00:26, bytes 169852202, flags -
is any one what cause this
Rishabh Seth
Level 7
Level 7
You would see this if the source and destination both are reachable over same interface. By default ASA blocks such communication. To permit this flow following command is required same-interface traffic permit intra-interface. You must have enabled it for your network requirement.
hope it helps!!!
R.Seth
mark answer as correct if it helps in answering your query.!!
