unable to run/Launch asdm on asa
nazim.bashir
 I have trouble launching asdm, i have enable the https access. but when i run on browser after adding expception on firefox i get below error
404 Not Found
The requested URL /admin/public/index.html was not found on this server.
I added the url on java as well as trusted url,
aydinnmu1
Hi body,
Please send your configuration:
show runn all http
show runn all asdm
Sincerely.
Hi Aydinnmu
 please see output below
http server enable 443
http 172.17.2.139 255.255.255.255 Management
METRDG-ASA01/pri/act# show runn all asdm
no asdm history enable
Hi my friend,
you must specify asdm file path your configuration.
asdm image disk://asdm_version.bin
I guess you set up your authentication use following command.
aaa authentication http console
Best regards.
Thank you so much following command posted by aydinnmu1helped!
