04-08-2011 04:58 AM - edited 03-11-2019 01:18 PM
I am trying to follow this example:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080b1ee95.shtml
I use a CISCO ASA 5505 with ASA 8.3. Everything works fine, but when I type the following line I get an error message:
nat (inside,outside) source dynamic OBJ_SPECIFIC_192-168-1-0 10.1.5.5
ERROR: 10.1.5.5 doesn't match an existing object or object-group
I even tried to create the missing object but it did not help.
The document also explains how to use ASDM for this configuration. It seems that there an object 10.1.5.5. is created.
This is the output of "show running-config":
ASA Version 8.3(1)
hostname ciscoasa
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 10.1.5.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network OBJ_GENERIC_ALL
object network OBJ_SPECIFIC_192-168-1-0
subnet 192.168.1.0 255.255.255.0
object network OBJECT1
host 10.1.5.5
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:3faad4ecef3961231629434dae91570c
: end
I am sure it is a stupid mistake on my side. Any help would be greatly appreciated.
Tobias
04-08-2011 05:11 AM
Hi Tobias,
try this
nat (inside,outside) source dynamic OBJ_SPECIFIC_192-168-1-0 OBJECT1
you have an object:
host 10.1.5.5
you need to call this object instead of the ip in the manual nat statement.
Ullas
