Unicast Reverse Path Forwarding Cisco ASA
ksarin123_2
I have disabled Unicast RPF on a Cisco ASA 5510 for one specific interface. However, how do I verify that RPF indeed has been disabled on that particular interface? It doesn't show up in the config, neither does it up when I issue the command "sh int interface'.
To disable the RPF feature, I issued the following command:
no ip verify reverse-path interface interface_name
Thanks!
Jennifer Halim
Unicast RPF is disabled by default on the ASA unless you explicitly enable it on an interface.
Since it is disabled by default on all interfaces, you will not see them in the configuration. Once you enable RPF for a specific interface, you will see that enabled in the configuration.
For example:
If you have 3 interfaces: inside, dmz and outside, and you enable it for inside only, then when you perform "sh run ip verify reverse-path", you will see the following:
ip verify reverse-path interface inside
OR/ you will see that in the running configuration as well. The other 2 interfaces that you haven't explicitly enabled will still be disabled by default, and will not show under the configuration.
Hope that answers your question.
Jennifer Halim
For example:
