09-19-2017 10:45 AM - edited 02-21-2020 06:19 AM
Hello
I upgraded the OS on our ASA 5505 from asa917-9-k8.bin to as917-16-k8.bin to mitigate the 200 day bug. All but one ASA upgraded nicely and can be reached by ASDM. This ASA upgraded but I can't connect to it in ASDM. It is the only device with multiple contexts system and notsystem. I have ASDM 7.6.2 on all ASA.
With ASDM open and other devices added I click on the IP address of this ASA just upgraded and it errors out-Device Error: Could Not Open Device <IP ADDRESS>.
Solved! Go to Solution.
09-19-2017 12:50 PM - edited 09-19-2017 12:51 PM
I found a solultion myself.
I issued the following command to get everything working:
ssl encryption aes256-sha1 aes128-sha1 3des-sha1 des-sha1
Looks like for some reason the device didn't have the ssl encryption enabled for the asdm to work.
09-19-2017 12:57 PM
You don't want to enable DES nowadays ... And also 3DES is typically not needed anymore if you don't have to support Windows XP.
