Vlan translation and inspection of Firepower 2110
neroshake
I have the following situation.
Router 2951 with G0/0/0 with 25 subinterfaces, each for its vlan.
Also have a pair of Firepower 2110 appliances managed by FMC.
The goal is:
1. To translate all these 25 vlans into one.
2. Do the basic Firewall and IPS inspection of the traffic passing from these 25 vlans and to them.
Can I accomplish this via Firepower? If so I think there are two options - using Inline Pair or BVIs. Per my understanding I will not be able to change vlan tags using Inline pair. So the only option is to use BVI somehow. Will it work if I create a BVI between 25 interfaces on one side and one on the other? If so, how will I be able to do firewall and IPS checks on traffic flowing in that link? Thanks!
0 Replies 0
