04-18-2013 11:26 AM - edited 03-11-2019 06:31 PM
Is it possible to have or setup VPC on an ASA? even if you are doing routing on the ASA? i was looking through:
anyone that has some experience with this i would appreciate it.
04-18-2013 11:36 AM
Yeah, it does.
In fact in the link you provide us you have all the details:
As you know you must be running a version higher than 8.4 so you can use LACP
Remember to rate all of the helpful posts
04-18-2013 11:37 AM
To my understanding on the ASA side you simply configure a Port-channel. The actual physical links of the ASA are connected to different Nexus devices.
Our Active/Active ASA pair for example is connected to pair of Nexus5k on both datacenters.
I think the document you link actually has a section in it for ASA configurations also in Routed mode.
- Jouni
04-18-2013 11:50 AM
i heard that when and if dynamic routing is happening then it will create an issue. this is why i am a bit confuse as everything seems to say that you can.
