WCCP - HTTPS Redirection
spencermoore
Level 3
Level 3
Hello, everyone. Need some assistance with WCCP HTTPS redirection. I've applied the configurations, but it seems the ASA isn't redirecting any HTTPS traffic. I've confirmed with the web-filter support personnel that the traffic never arrives at the appliance. Web-cache (port 80) is working without issue. After generating traffic from a test machine I do not see the ACL counters increment. Any help would be much appreciated!!
asa912-smp-k8.bin / ASA5515x
Config:
wccp web-cache redirect-list WCCP_REDIRECT_HTTP group-list WCCP_GROUP
wccp 70 redirect-list WCCP_REDIRECT_HTTPS group-list WCCP_GROUP
wccp interface inside web-cache redirect in
wccp interface inside 70 redirect in
Show:
Global WCCP information:
Router information:
Router Identifier: 192.168.254.1
Protocol Version: 2.0
Service Identifier: 70
Number of Cache Engines: 0
Number of routers: 0
Total Packets Redirected: 0
Redirect access-list: WCCP_REDIRECT_HTTPS
Total Connections Denied Redirect: 0
Total Packets Unassigned: 0
Group access-list: WCCP_GROUP
Total Messages Denied to Group: 0
Total Authentication failures: 0
Total Bypassed Packets Received: 0
WCCP Routers Informed of:
-none-
WCCP Cache Engines Visible:
-none-
WCCP Cache Engines NOT Visible:
-none-
Francesco Molino
could you give more information please?
Does web cache server and clients are behind the same interface of the asa? Otherwise it will never work. I mean if inside asa interace is on the network 192.168.0.0/24, webcache server and clients must be on the same segment.
if you are respecting this prerequisite, config looks like as below:
acl for classifying all webcache server:
access-list wccp-srv permit ip host 192.168.x.x any ==> web cache server ip
Acl for traffic that needs to be redirected:
access-list wccp-clients permit tcp 192.168.x.0 255.255.255.0 any eq 443 ==> you want to redirect only hhtps traffic
Enable wccp:
wccp web-cache group-list wccp-srv redirect-list wccp-clients
Redirect traffic on the inside:
could you compare your config with this template?
hope this is clear.
You can also use service-id, take a look on :
http://www.cisco.com/c/en/us/support/docs/security/adaptive-security-appliance-asa-software/116046-config-wccp-asa-00.html
thanks.
PS: please don't forget to rate and mark as correct answer if this solved your issue.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Kias
Level 3
Level 3
ACL:
access-list wccp-http extended deny ip host <wccp server ip> any
access-list wccp-http extended permit tcp object-group <LAN subnet> any eq www
access-list wccp-https extended deny ip host <wccp server ip> any
access-list wccp-https extended permit tcp object-group <LAN subnet> any eq https
access-list wccp-server extended permit ip host <wccp server ip> any
The acl is built for http, https and wccp-server as above. This configuration works for us.
Have you checked the traffic on wccp server interface(gre) for any https traffic using tcpdump/ngrep?
If you can't see the traffic it could be router identfier issue on the asa or firewall settings on the wccp-server.
Kindly advise.
Kias
Kias
Fonicom Limited
raiseaticket Malta
