We need to enable SIP from outside to inside (ASA 5505)
ralf.rottmann
Hi there,
We recently purchases the Cisco ASA 5505 to get familiar with it, possibly buying more appliances for our branch offices. However, since the appliance is installed, our SIP telephones no longer register with our SIP service provider.
The SIP phones are all on 10.0.1.0/24 while the SIP provider is external via the outside network. I copied our configuration below. Can anybody advise how to enable SIP for all 10.0.1.0/24 hosts and ports 5060, 5160, 5260, 5360?
This matter is pretty urgent...
gcxfw# show running-config
: Saved
ASA Version 8.4(3)
hostname gcxfw
domain-name ***
enable password *** encrypted
passwd *** encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 12
interface Vlan1
nameif inside
security-level 100
ip address 10.0.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 195.14.245.70 255.255.255.224
interface Vlan12
nameif dmz
security-level 50
ip address 10.0.2.1 255.255.255.0
ftp mode passive
dns domain-lookup inside
dns domain-lookup outside
dns server-group DefaultDNS
name-server 194.8.194.60
name-server 213.168.112.60
domain-name ***
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network obj-10.0.1.0
subnet 10.0.1.0 255.255.255.0
object network obj-10.0.2.0
subnet 10.0.2.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (dmz,outside) source dynamic obj_any interface
nat (inside,dmz) source static obj-10.0.1.0 obj-10.0.1.0 destination static obj-10.0.2.0 obj-10.0.2.0
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 195.14.245.65 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.0.1.0 255.255.255.0 inside
http 0.0.0.0 0.0.0.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
  quit
telnet timeout 5
ssh 10.0.1.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 5
console timeout 0
dhcpd dns 194.8.194.60 213.168.112.60
dhcpd auto_config inside
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username *** password *** encrypted privilege 15
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
class class-default
  user-statistics accounting
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
hpm topN enable
Cryptochecksum:3636b3a4cffda0c099e3e65ba598164f
: end
ralf.rottmann
We solved half of the issue by enabling sip inspect as outlined in the documentation. However, in addition, we need to enable it for port 5160 (5060 is working). How can we do that?
class-map SIP
match port tcp eq 5160
class SIP
Inspect SIP
Do rate all the helpful posts
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
