Welcome to Cisco Firewalls Community
1495
Beginner
Zone Based Firewall Performance issues on ASR 1004
Hi all,
we are experiencing performance issues on ASR 1004 with ZBF as our campus edge router.
Symptoms:
- sending small packets from inside zone to outside zone, for example UDP packets without payload
- this way I can generate up to 150.000 pps traffic (testing with packeth software, but we have had a real example with some kind of worm/virus)
- CPU load is about 1% (yes one!) to 2% all time !! (weird)
- ASR response to pings rises very quickly up to 5 seconds which makes box unusable dropping everything what goes through ZBF (so internet connection is gone)
- if I do the ping directly from box, it seems to work fine (no rules from self to outside zone in ZBF)
- if I remove interfaces from inside and outside zone (so disabling ZBF) and do the test again, ASR response goes from normal (0.2ms) up to 2ms (still sending 150.000 pps) and everything seems to work fine)
Config:
- two inside interfaces
- one outside interfaces
ZBF:
  Policy Map type inspect IN2OUT
    Class I2O-DENY
      Drop log
    Class I2O-SSH
      Inspect TCP12H
    Class I2O-PERMIT
      Inspect NORMAL
    Class class-default
      Drop log
  Policy Map type inspect OUT2IN
    Class O2I-FTP
      Inspect
    Class O2I-H323
      Inspect
    Class O2I-DNS
      Inspect
    Class O2I-SSH
      Inspect TCP12H
    Class O2I-PERMIT
      Inspect NORMAL
    Class class-default
      Drop
The most campus traffic to internet goes through class "I2O-PERMIT" with inspection:
show class-map ty inspect I2O-PERMIT
Class Map type inspect match-any I2O-PERMIT (id 1)
   Match protocol  ftp
   Match protocol  sip
   Match protocol  icmp
   Match protocol  tcp
   Match protocol  udp
   Match access-group name  I2O-PERMIT
show parameter-map type inspect NORMAL
  log dropped-packet off
  audit-trail off
  alert on
  max-incomplete low  unlimited
  max-incomplete high unlimited
  one-minute low  unlimited
  one-minute high unlimited
  sessions rate low  unlimited
  sessions rate high unlimited
  udp idle-time 30 ageout-time 30
  udp halfopen idle-time 30000 ms ageout-time 30000 ms
  icmp idle-time 10 ageout-time 10
  dns-timeout 5
  tcp idle-time 3600 ageout-time 3600
  tcp finwait-time 5 ageout-time 5
  tcp synwait-time 30 ageout-time 30
  tcp max-incomplete host unlimited block-time 0
  sessions maximum unlimited
  gtp permit error off
  gtp  request-queue 40000
  gtp  tunnel-limit 40000
  gtp  gsn timeout 30
  gtp  pdp-context timeout 30
  gtp  request-queue timeout 60
  gtp  signaling timeout 30
  gtp  tunnel timeout 60
According to Cisco Datasheets: routing, Qos, Zbf ... on ASR 1000 with RP1, ESP10 should be done in hardware with up to 17.000.000 pps performance (and our box can kill only 150.000 pps)
Any ideas what could be worng?
Thank you for your suggestions.
Pavel
5 REPLIES 5
js Beginner
Beginner
Hi Pavel,
Any news yet on this problem? Or even better, a solution? I'm having the exact same thing. Firewall enalabled = no performance...
Thanks for your update.
KR,
Jan
Beginner
Hi Jan,
unfortunately no solution yet :-/
I hope some cisco guy can help?
Pavel
Hi Pavel
anything new since this post ?
did you manage getting over 150000 ?
Beginner
Hi there,
no, there are no news, we used the workaround - acl denying all packets with destination port 0.
Pavel
Beginner
Ok, I forgot to say, that the problem was caused by malicious trafiic flowing from inside to outside - small UDP packets with destination port 0. Maybe it was some virus or worm ...
Pavel
Content for Community-Ad
FusionCharts will render here
