Welcome to Cisco Firewalls Community
185
Highlighted
Beginner
Zone-Based Policy Firewall help
Looking for necessary commands to do the following policy:
You should allow web traffic (HTTP and HTTPS  ONLY) to get to the Server (192.168.2.3 /24) in the DMZ of R1 (R1 G0/0 – 192.168.2.1 / 24). Allow pings to the DMZ server as well.
Everyone's tags (1)
1 REPLY 1
Highlighted
VIP Advocate
Re: Zone-Based Policy Firewall help
You could do something like the following:
ip access-list extended web-to-dmzServer-acl
 permit tcp any host 192.168.2.3 80
 permit tcp any host 192.168.2.3 443
class-map type inspect match-any web-to-dmzServer-cmap
 match access-group web-to-dmzServer-acl
policy-map type inspect web-to-dmzServer-pmap
 class type inspect web-to-dmzServer-cmap
  inspect
zone security dmz
 description DMZ services
zone security web
 description Internet
zone-pair security web-to-dmz-pair source web destination dmz
interface Gig0/0/0
 zone-member security web
interface Gig0/0/1
 description DMZ
 zone-member security dmz
Verification:
show policy-map type inspect zone web
show policy-map type inspect zone dmz
show policy-map type inspect zone-pair web-to-dmz-pair
Keep in mind that inspect allows return traffic of the same flow.  However if you require the DMZ servers to initiate traffic to other servers, PCs, or the internet, then this needs to be taken into account and added into the configuration.  The configuration I have provided only allows for HTTP and HTTPS towards the DMZ server.
Please remember to select a correct answer and rate helpful posts
Content for Community-Ad
FusionCharts will render here
