Small Business Support Community
Explore what Cisco has to offer for your small business IT needs. Learn from your peers and Cisco experts.
Browse the Community
Routers - Small Business
Routers tailored for small businesses, providing efficient and reliable connectivity for your growin...
Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small busi...
Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost product...
Cisco Business Dashboard
Stay on top of your business performance with the Cisco Business Dashboard, providing real-time data...
Activity in Small Business Support Community
CBD 2.7.1 Error while using a wildcard certificate
I'm running CBD2.7.1 and installed a public wildcard certificate.The following error is flashing on the top of the dashboard:"Server certificate does not contain your server address in Subject Alternative Name."Is this a bug when using wildcard certs...
SteveKC by Level 1
  • 94 Views
  • 3 replies
FTD intervlan questioning,
Scenario,Host-A(10.10.30.3/24) connects to access port on SwitchA with various other vlans also configured via access ports. SwitchA connects on a Trunk port to a CatSwitch. Firepower inside ½ interface trunks to CatSwitch. On The CatSwitch 3 vlans; ...
GatLMCO by Level 1
  • 233 Views
  • 11 replies
Firmware update
HI,i am trying to update my SG500 and SG 300 series switch to latest firmware. currently running in 1.3.0.62 and planning to upgrade to 1.4.11.5. i have downloaded the firmware from cisco portal sx500_fw-14115.ros. while performing i am getting an be...
ziyadps by Level 1
  • 129 Views
  • 7 replies
VLAN configuration RV042G & CBS220
 HelloI'm trying to set up VLAN's but can't get it working.I have these components- firewall Cisco RV042G- Switch Cisco CBS220What I would like to create is three separate VLAN's with192.168.1.1 (my default LAN)vlan-2 192.168.2.1..vlan-3 192.168.3.1....
Software Patching and Updates
Hi all,The license of Cisco Switch has lapsed. Would it still eligible to obtain software updates and subsequent patching? As my current Cisco Switch did not renew the license while looking the trend of new vulnerabilities arising from time to time. ...
initializing network
hello, we have a cisco spa504g at my work place connected through Telstra. it has been saying 'initializing network' for 2 days now and the microphone button is red. we have tried resetting/restarting in each and every way but no changes. also the ph...
Switch power shuts down on it's own
We have a Cisco Switch 350 that just powers down on its own. The logs do not show anything as it is a limited log and cleared when it powers off. It happens often and it's not a power outage or power brownout. The switch is also on a good UPS and we ...
