PLEASE NOTE: The Kinetic developer discussions are moving to the main Kinetic board.
You should get a more active community response there.
515
chandlerheath
Beginner
829 Unified AP configuration does not join controller over cellular
With Unified AP enabled, and the WLC IP address of the primary controller set in the configuration of the template used for the 829 gateway, it doesn't appear to try and connect. Is this feature in GMM fully supported?
1 REPLY 1
Steve Zhang
For the latest version of Kinetic, it supports the Unified AP. You may configure the Unified AP in the Template.
If you still meet the issue, you may create a TAC case accordingly.
Hope it helps. Thanks.
Content for Community-Ad
