01-26-2019 01:36 PM
trying to figure out what next to do on ISE so when I apply the command "sho authentication sessions" I should see the Method - as MAB - Domain as Voice and Status as Authoz success
SW-lab#sho authentication sessions
Interface MAC Address Method Domain Status Fg Session ID
Gi1/0/3 c4b9.cdb5.325e N/A UNKNOWN Unauth 0A16640A0000001B874935A0
Solved! Go to Solution.
01-27-2019 03:11 AM
You havent left enough information to work on except that the device is unauthenticated.
I recommend you take a look at this design guide for IP Telephony with 802.1x as well as MAB
Really good article which also shares the flow explanation.
01-26-2019 02:28 PM
01-26-2019 11:53 PM
01-27-2019 03:11 AM
